headers installation question
Old Apr 20, 2008
BoneStOck_176's Avatar
BoneStOck_176 is an unknown quantity at this point
I'm installing a 4-2-1 header on my ek coupe. I see on the stock header there is some sort of sensor connected between two of the pipes. My question is do I just disconnect this sensor or do I have to make adjustments to my aftermarket headers!!
Old Apr 20, 2008
CivicHatch9one's Avatar
7th gen old timer.
CivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond repute
Re: headers installation question
whaaaaaaaaaaaaaaaaat?
thats the o2 sensor. take it out the stock one and put it in the new one. you will get a cel otherwise.
Old Apr 20, 2008
where do I put it. I dont c a designated insert for it
Old Apr 20, 2008
7th gen old timer.
ether weld a bung in or http://www.o2simulator.com/
how many wires are coming out of the sensor.
Old Apr 20, 2008
thanks man!! Can u check the thread l8r I'm at work now and won't b able to check how many cables
Old Apr 20, 2008
its 4 cables. Two black wires, one green, one white
Old Apr 22, 2008
sql_civic's Avatar
The 6th gen Civics all have 4 wire O2 sensors and there are 2 of them. One before and one after the cat. If you have an LX or DX coupe then you'll have to install a bung for the secondary otherwise move the primary sensor from your old stock header into the bung that came with your new header.
EK_Eddy
Jun 6, 2015 07:31 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
SlvrEX5spd
Nov 17, 2001 10:11 PM
SlvrEX5spd
Nov 17, 2001 03:33 PM
colombianDXcivic
Nov 8, 2001 12:14 AM
