99 EX, need to know?
Old Feb 1, 2008
Bertscookie's Avatar
Bertscookie is an unknown quantity at this point
I have a 5-spd Manual 99 EX civic with 150k+ on it. Smooth sailing so far.... This is my first Honda and I was wondering if there was anything I need to know or watch out for.
Old Feb 5, 2008
Nitro Express's Avatar
Nitro Express is an unknown quantity at this point
Re: 99 EX, need to know?
when was your timing belt replaced? if you don't know, get it done.
Old Feb 12, 2008
NJWarren's Avatar
NJWarren is an unknown quantity at this point
Nitro's advice would be the best thing to look into If you don't know when it was done it may need done... esp if there are any unusual noises coming from the timing belt area... another thing to watch out for is at about 170K the Catalytic converter will probably go bad, so if your engine check light comes on around there thats probably what it is... (I have a 2000 LX and the cat went out at about the usual time... 173k they are like $800 for the oem part from Honda... DONT get it... get a cheap aftermarket one... actually better than the one piece oem one... and You can get em anywhere from 175-350 (oxygen sensors are a good idea around that time too)
Hope this helps... =D
Old Feb 12, 2008
NJWarren's Avatar
oh ya... o2 sensors can run ya up to 300 buck ea from a honda place, get
specifically made bosch ones... (89-100 bucks) and are just as good as the NGK ones...
Old Feb 15, 2008
sql_civic's Avatar
The O2 sensors usually go bad around 100k miles. You can get them at NAPA for about $90 or so. You'll know it's time when you get a CEL.
