COOLANT levels DROPPING!!
Old May 3, 2007
ELLAS1945's Avatar
ELLAS1945 is an unknown quantity at this point
I recently bought this 96 LX civic and I thought I would baby it,, so it can last. I went to synthetic, for the past 3 week I've been using high premium gas, replaced timing belt and water pump, and replaced spark plugs.. But..
Last weekend I checked my coolant levels and it had just a touch in the reservoir but the rad was full. I filled it in between the min and max and again this morning I noticed it dropped a bit of coolant..
so wtf is the problem
thanx !!! any help please
Old May 4, 2007
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
Re: COOLANT levels DROPPING!!
is it leaking into your cylinders? AKA blown head gasket. check and see what color your the smoke coming out of the exhaust is. i think if its white then its coolant. check all your hoses and radiator for leaks.
Old May 5, 2007
Got Boost?'s Avatar
Got Boost? is an unknown quantity at this point
Run a compression test on your collant system for any leaks could be minor if anything but you never know
Old May 7, 2007
sql_civic's Avatar
Why are you using high premium gas? Do you mean high octane? If so stop using it. It's not "better" gas. Use 86 octane as recommended by Honda. High octane gas is intended for high compression engines which your stock LX is not. But I digress...
Make sure the cap on your radiator and reservoir are firmly closed. Keep checking the reservoir. Maybe the fluid was just low when you bought the car.
andyandyy
Aug 4, 2015 06:37 PM
frisbeeguy2
Jul 30, 2015 03:00 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
