keyless entry 1996 Civic
Old Jul 3, 2006
bachlr's Avatar
bachlr will become famous soon enoughbachlr will become famous soon enough
Angry keyless entry 1996 Civic
Hi all.
The car is a 1996 Honda Civic Lx. I bought this car used and it did not have a keyless entry key fob with it. I bought one on eBay and am not being successful at programing it to the car. The tiny red light at the top comes on when I press a button so I assume the battery is good.
I found the intructions that said to push the valet disarm button beween the tape/cd button and AM/FM button.
After putting the key in II position, holding the button between the tape/cd and am/fm button, the locks should cycle, but they don't... It just sits there, nothing happens. Power locks work fine on the doors. Is there something missing on this car that wont allow it to go into the programing mode? I was under the impression that if it has power locks, and has the factory radio, that it is set to go for programing keyless entry.
PS: Could it be a fuse? Also I read that there is something behind the cig lighter with FCC stuff on it on new Honda's. Does this apply to a '96?
Thoughts?
Old Jul 6, 2006
AdmireMyGr8ness's Avatar
SuperMod a.k.a ~AMG~
AdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond repute
My only thought is that the car might not have come with keyless entry. If I remember correctly keyless entry was an option. Just because you have power door locks...doesn't necessarily mean that you have the keyless entry module. I'll look further into it and see if I can be of more help to you. One thing you might want to check is the fuse panel on the underside of your dash and see if there's a fuse in the keyless entry position. It's possible if there isn't a fuse there, then there may not be a keyless entry for the car....just one thing to look at in the mean time.
Old Jul 6, 2006
bachlr's Avatar
Which fuse is the keyless entry?
I am missing the cover under the dash that has the diagram for the fuses. Could you help me find out which fuse controls the keyless entry? Thanks, John
Old Jul 7, 2006
I'll try to take a picture of mine and post it soon.... It might not be until Monday though...I don't have my data cable with me.
Old Jul 7, 2006
bachlr's Avatar
A picture would be great!
Thanks for your time on this! I appreciate it!
Old Jul 10, 2006
I did kinda take this from a search this is what someone posted on clubcivic.com
Old Jul 12, 2006
bachlr's Avatar
Thanks for the picture
The picture will help me locate the door lock fuse and see if that is the problem. Thanks for your time on this!
Old Jul 12, 2006
It's the same fuse as the "cruise Control" fuse. Lots of luck!
Old Jul 14, 2006
bachlr's Avatar
I believe the cruise control works right now, so it may not be the fuse after all. It could be that it needs the FCC box installed
darwin-t
Apr 18, 2015 09:29 PM
Killagi
Apr 12, 2015 10:42 AM
CivicChick2k1EX
South
Nov 13, 2001 10:38 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
