Integra Type R pistons
Old Jul 10, 2003
tiredwolf's Avatar
tiredwolf is an unknown quantity at this point
will integra type R pistons fit in a B16? thanks for any help.
Old Jul 14, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Um, I don't think they will. The displacement for the B16 is 1.6 L. The Type R is 1.8 L.
But I could be wrong... Maybe with a little overboring they could.
Old Sep 12, 2003
quicksi's Avatar
quicksi is an unknown quantity at this point
The Integra Type R pistons will fit in a B16. You will get a nice little bump in compression and can use the stock rods. The only B series pistons that will NOT fit, will be the B20 pistons because of the bore, and the CIVIC Type R pistons because of the rods. Now, if you machine the B16 rods, the CTR pistons WILL fit, but they will give off nearly 12.1 compression, and without cam gears, a VAFC, a dyno, and alot of dyno time tuning it out, you are going to have porblems, especially if yo udo not have high octane fuel in your area.......
Old Sep 12, 2003
quicksi's Avatar
You are right about the displacement being different, but that is because of the stroke in the motors. Both engines use an identical block, the only differences are the crank which gives off a longer power stroke for the ITR. The B18C5 stroke if I recall is somewhere around 87mm and the B16A2 stroke is somewhere around 77MM. That is mostly the MAIN reason the ITR makes more power, while having the same bore as the Si. .
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
anubis62
Sep 27, 2015 12:56 AM
speedlever
Sep 24, 2015 07:18 PM
