What else can cause front end noise?
Rep Power: 0 What else can cause front end noise?
I have a 2004 Civic and have noises coming from the front end. I inspected everything and found several worn parts.
So far I've replaced:
complete strut assembly all around
Front lower control arms
Ball joints
Sway bar end links
Outer tie rod ends
Still getting a metallic rattle over rough road.
The wheel bearings seemed fine and the CV axles appear to be in good shape no leaks or tears.
What else can cause noise in the front that I should look at? Thanks in advance
Ball joints
Sway bar end links
Outer tie rod ends
Prelude Owner
Re: What else can cause front end noise?
Did the strut assemblies come with new strut mounts? The bearings can wear and make a rattle sound over bumps. Also make sure your end links are nice and tight.
Rep Power: 0 Re: What else can cause front end noise?
The strut assembly came with everything. New mounts, springs, etc.. The end links are new and everything is tight.
Rep Power: 78 Re: What else can cause front end noise?
did you also replace these bushings on the swaybar? these are a common cause of your issue that is often overlooked by most people.
I put a set of quick struts on something older a while back.......found that someone at Monroe never tightened the big nut in the middle of the strut cap
I frequently see replacement sway bar links with loose nuts, someone never got them tight enough when installed.
Received 1,443 Likes
Rep Power: 338 Re: What else can cause front end noise?
i had a mysterious flapping noise. it was a zip-tie that got in the way of the radiator fan.
I had a mysterious clank. Ended up being a cracked control arm...
i had a mysterious clunk in the back of the car during acceleration or braking - it was a coke glass bottle under the seat that previous owner forgot there...
in other words, could be a lot of things. lots of stuff in the front of a FWD car...
brake shields?
brake shields?
I had a chance to lift the car and go over it again and I found one of the wheel bearings to be bad. There's a small amount of play that either wasn't there before or I just assumed it was caused by the ball joint. Thanks everyone for the help. I'll be back if a new wheel bearing doesn't fix it.
leech64
12-24-2016 02:51 AM
laack
03-04-2010 01:49 PM
