02' Civic LX Trunk Release Broken?
Rep Power: 0 02' Civic LX Trunk Release Broken?
Hey, I'm quite new to the forums. So here I go.
I have an 02' Civic LX (4dr) and the trunk release switch does not work, when I push down on it the gas tank opens fine, but when I pull it to open the trunk I get no feedback (almost feels as if its stuck). I opened the trunk and found the wire that "supposed" open it, and when I push and pull on the wire the actual release switch (on the floor of the driver side) moves up and down.
Any help or advice would be greatly appreciated.
Re: 02' Civic LX Trunk Release Broken?
Turn the lock on the release lever with your ignition key.
It sounds like it is locked.
Or there is a problem, it will most likely be found by removing the door sill trim panel to investigate.
HTH
HTH
carhag2000
04-25-2015 01:33 PM
djdefcon
17
04-06-2005 11:52 PM
CiViCPrAnInG2k1
11-01-2001 03:47 PM
