02 to 04 front end swap. Need help with headlights.
Old Mar 27, 2018
Ochoa909's Avatar
Ochoa909 is an unknown quantity at this point
So I got into a small front end accident last week and I'm replacing everything and I thought. Why not change my 02 front end to a 04 I know what I need to do this. But I'm not really electrical savvy so this is where I need help. I know the 04-05 headlights have separate low and high beams. So what do i need to make them work on my 02? I've been looking around and haven't found any answers. Do i need a whole new wiring harness or can I make it work with the current one.
Old Mar 27, 2018
Re: 02 to 04 front end swap. Need help with headlights.
Either make an adapter harness (h4 [male] to 9006/9005 [male]) or buy one would be the easiest route
$50 for a pair here: http://innovativewiring.com/?page_id=1551
$25 for a pair on ebay: https://www.ebay.com/itm/H4-to-9006-...JaiRbw&vxp=mtr
If you want your lows to stay on with your highs, you'd probably be better off buying a relay harness from theretrofitsource.com. Considering an H4 relay harness is only $35 plus shipping, and they use quality stuff, wouldn't be a bad idea
https://www.theretrofitsource.com/wi...n-h4-9003.html
HID inputs use 9005/9006 plugs anyways, so there'd be no further conversion needed. Just find a place to mount the relay, route the wiring, and "tap" a connection from the battery (really, really easy to do) and you're solid. Oh, and tape over the unused H4 connector for safety. The relay harness only uses one input from the car. Their "install guide" diagram is rather straightforward, too.
Old Mar 27, 2018
Ochoa909's Avatar
Wow. Thanks alot, finally something usefull. Now I just need hid bulb and ballast.
Old Apr 2, 2018
Ochoa909's Avatar
I got another issue lol. What do I do about the turn signals?
Old Apr 2, 2018
I thought they used the same bulbs and sockets. I got nothing for that one.
Old Apr 2, 2018
Colin42's Avatar
Splice on the 04 socket, use either heat shrink crimp connectors or solder and heat shrink
killerkilo3
Mar 28, 2012 10:10 AM
blouisgod
Florida
Mar 1, 2006 08:04 PM
coolness5545
Oct 13, 2005 09:50 PM
DC
Sep 16, 2002 05:25 PM
Polkayman
May 19, 2002 06:34 AM
