CHECK ENGINE LIGHT 2004 Honda’s civic LX
Alrighty so just a heads up I’m 17 got my first car and I don’t know **** about cars 😂😂🤦🏻*♂️ Soooo with my luck my first car was a lemon they sold me a salvage check engine light ****ed up head gasket and transmission car for 4,000$ I took the L and now I’m trying to fix it.
i was able to fix everything I thought now I have the check engine light that’s throwing the code p0741 would you guys have any clue what would it be? I did swap the tranny not sure if that’s an issue
Re: CHECK ENGINE LIGHT 2004 Honda’s civic LX
P0741 Problem in lock up control system
The PCM detected slippage of the torque converter clutch and set the code.
Why? IDK, lots of possible reasons.
TCC solenoid not connected correctly?
TCC solenoid broken?
TCC solenoid bad?
(these can happen during engine or trans work)
CPC solenoid valve A/B fault?
Incorrect fluid used?
Low fluid level? High fluid level?
You replaced the transmission?......did you also replace the torque converter, or did you reuse the old one?
Did you thoroughly flush the ATF cooler before installing the trans?
Used trans, how do you know it wasn't already having problems before you got it?
Got your airbag recalls done yet?
TCC solenoid bad?
streetglower
47
Jun 14, 2019 06:14 AM
eebing
Sep 12, 2015 05:35 AM
streetglower
Electronics DIY
82
Sep 7, 2013 07:05 PM
tim210g
Jan 11, 2013 11:31 PM
pcheruka
May 5, 2009 03:14 PM
