Thermostat temps
Old Feb 6, 2018
hdtrc's Avatar
hdtrc is an unknown quantity at this point
Thermostat temps
Hello,
While looking around for a replacement thermostat I noticed that they are available in 170°, 180°, and 195°.
Why the different choices ?
2005 Civic LX 5speed
Old Feb 6, 2018
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Re: Thermostat temps
Usually companies make you think that running a lower temp thermo is better for the engine and gain performance, but this is not true. Or people try them in the hopes of fixing an overheating issue....
Just stick to oem and let your car run as it should. Here's a link to an article I found online explaining in greater detail.
http://www.tuneruniversity.com/blog/...the-advantage/
Old Feb 6, 2018
OE spec:
Begins to open @76-80*C
Fully open @90*C
Lift@full open 8.0 mm
Old Feb 8, 2018
hdtrc's Avatar
According to both Stant and Gates, the OEM thermostat temp is 170°F. The optional choices are higher at 180°F and 195°F.
The article supplied by GusBuz is about thermostats that have lower than OEM temperatures.
What is the advantage or need for higher temps ?
Old Feb 8, 2018
Colin42's Avatar
just get the oem and stick it in
Old Feb 8, 2018
Slumpertcivic's Avatar
Maybe a Canadian thing, moar toasty inside heat makes them happy.
Old Feb 8, 2018
Fuel efficiency/economy.
Old Feb 9, 2018
mikey1's Avatar
the best stat is the stock stat....end of story....just go to your honda dealer and avoid all the hassle and complications
Old Feb 15, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Get an OEM thermostat and call it a day. I got mine on Amazon. Honda has designed the engine to run best at a specific temp, so just stick with OEM. You won’t help anything by going aftermarket, and you could cause problems. If the engine runs too cold, you will have a lot of wear and bad gas mileage. If the engine runs hot, wear will increase and you are more likely to overheat.
Roosbok
Oct 11, 2022 09:38 AM
2002ExCivic
16
Nov 29, 2016 08:29 AM
Ashhole
Nov 22, 2005 07:57 PM
Boilermaker1
Auto X/Road Racing
Jun 19, 2004 10:03 PM
B
Aug 7, 2002 02:18 AM
