Whats de difference between BMXA transmission built in canada thank BMXA built in USA
Old Oct 13, 2017
rbn315's Avatar
rbn315 is an unknown quantity at this point
Hello i have a bad tranny 2005 civic DX non vtec,,bought a used one 2003 EX v-tec,, both trannys looks identical did my research and found my DX especcs says w/OD,,and the EX says w/OD lock up torque converter,,,so before i installed i wanna make sure the EX fit in my DX since they both are BMXA but one is made in canada and the other one in USA thx.
Old Oct 13, 2017
Re: Whats de difference between BMXA transmission built in canada thank BMXA built in
The trans for VTEC engine has different gear ratios than the other trans for non-VTEC engine
Old Oct 14, 2017
rbn315's Avatar
Thanx,,,so the EX transmission would no fit on the DX ,,,even do they are both BMXA?
Old Oct 14, 2017
I think it will bolt together but I don't know if the computer would set fault codes because of gear ratios it isn't programmed for.
Mix-n-match-n-pray swaps aren't my bag.
Forum search?
Maybe someone else will chime in with better info?
Old Oct 15, 2017
rbn315's Avatar
Went to columbus IN honda dealer culdnt give me that information, dont ask me why,,they just dont wanna help,,,i have 2 choices install it and s ee what happened,,or tare both transmission apart and inspect them,,
Old Oct 15, 2017
You're wanting info that dealers don't have in the first place, therefore no help.
We at dealers don't deal with mix/match/pray parts swapping.
If you wanted to purchase an absolutely correct replacement transmission selected using the VIN of your car, they would sell that to you in a heartbeat.
