What is Air Intake Manifold in car?
Rep Power: 94 What is Air Intake Manifold in car?
What is Air intake manifold and what are his job?
Does all car have air intake manifold? or some have and some not?
like i have Honda civic 2002, does it have it?
All same questions for Air intake Runner Control.
thanks a lot.
i am new learner how system work.
thanks a lot.
Received 1,451 Likes
Rep Power: 94 Re: What is Air Intake Manifold in car?
i know the wikipedia thing but their English is hifi i dont understand all their word so i come here to ask so like that i can ask you what i dont understand.
Rep Power: 339 Re: What is Air Intake Manifold in car?
not sure if this is a serious question, but i will play along
yes all cars have them,
your intake manifold is connected to the cylinder head, on this vehicle it is located at the rear of the engine close to the cabin,
what language do you originally speak?
also, if you knew, why asking?
also, DIY section is NOT for asking question, it's for people writing articles that are useful to others, so I am moving this to an adequate section.
i speak urdu.
no problem for moving. it is good idea.
so it is just a plastic with air passage letting air go in cylinder or fuel pass also with this, and that s all it do nothing more? i hear about upper manifold and lower manifold, i assume this one is lower manifold with air passage so what is upper one i dont see any other manifold. i can see air filter foxe top of trottle body and one big box some one say it is resonator dont know what is this one now.
An engine does not necessarily have to use a separate intake manifold at all.....a carburetor or throttle body could be attached directly to the cylinder head if a person wanted to, without any intermediate tubing or chamber between the two items.
Upper and lower MAY refer to how one is designed and assembled, it MAY refer to different areas such as a plenum chamber vs. runners, it MAY refer to multiple runner lengths and chamber sizes, it MAY refer to different areas within the assembled manifold (V8, SP/2P), and more.
Every manufacturer does things differently, and there might be 1,000,000 different designs.
On your particular engine it is one piece and it is made of plastic......but
An intake manifold does not have to be made of plastic. They are also made of cast aluminum, metal tubing, and cast iron used to be very common as well.
Casting and injection molding used to present limitations to manifold design.......but now a person can literally print a manifold on a 3D printer without having to consider those limitations.
urdu...
sorry, can't be of help there other than google translator...
why do you want to know? Hard to answer without knowing the why. answers could change based on that.
Also, finding a friend that knows cars is a better help than trying it on the internet. Urdu, so I suppose india? there's people there who knows cars, you could try to find one.
