Value of Full Size Spare
My tires are about at the end of their useful life and while I am buying new tires, I will probably take advantage of the situation and buy 16x7 alloy wheels.
I have been seriously considering the idea of purchasing five and having a full size spare. I understand flats/blowouts are rare and it is unlikely I would have the occasion to use it but...I make 450 mile round trips through Los Angeles to San Diego on a regular basis. The idea of using the donut on the 405 is a pretty uneasy thought.
Beyond that though, it would give me the option to change the tire once and be done with it. I could repair/replace the damaged tire and put it back in the trunk until the next rotation or incident.
Obviously the initial investment will be higher and replacing five tires is more than replacing four. Long-term though with proper care I won't have to replace tires as often.
I know the additional weight will reduce fuel economy. Any other cons I should be aware of?
Finally, anyone have experience with the fit of a full-size wheel/tire in the trunk well? I made a new trunk floor/spare cover out of 1/2" plywood. It covers the entire floor, not just the well.
Thanks!
Thanks!
Re: Value of Full Size Spare
Go for it, double check that the full size will fit ok and your floor will clear it. Depending on how bad your current tires are you could even use one of them as your spare. I doubt the extra couple of pounds would affect the fuel mileage that much, it's not a 35" mud tire. I miss having a full size spare back when I had my truck.
I just feel that we are blessed to have a compact spare!
A lot of companies give you a can of Flat Fix and wish you well.
I would say pull off one of your current wheels and see how it fits.
I just purchased five (16x7) wheels from autoanything. They were $376.64 delivered. I'm looking for tires now, proly going for some Cont Control Contact Touring or Mich Premier or Defender. I want the best ride I can get...
I'll have the brake lines bled when I get them installed. Keep it simple and save time.
http://www.autoanything.com/wheels-r...byrinth-wheels
