normal 17" wheel backspacing and tires
Old Aug 27, 2017
Sweetnsauer's Avatar
Sweetnsauer is an unknown quantity at this point
What's the wheel size, width, backspacing, and tire size you can run on 17s? I don't want ghetto rubber band tires that are peeling inward off the rim and the rims are sticking out. It's a 2005 civic ex
Old Aug 27, 2017
Re: normal 17" wheel backspacing and tires
I was thinking 225/55/17 for the tires?
Old Aug 27, 2017
It's not lowered btw.
Old Aug 28, 2017
225's have shown to be a bit wide for the 7thgen. 215/45-17 will fit with no issues and give you the most accurate speedometer reading with 17" rims installed.
edit: here are 215/45-17s on a lowered (~2" drop) civic. Best pic I could find at such short notice. Note the tires actually have some substance to the sidewall and aren't little ricer bands.
Old Aug 29, 2017
What's the backspacing? Those are perfect because they are tucked in a little bit and most 17s I see are flush with the fender
Old Aug 29, 2017
I am lowered and they damn near tuck in the rear. Thankfully, with suspension travel, the wheels' camber goes negative so it doesn't rub.
edit: took a tape measure outside and took some pics. Keep in mind my car's parked on an incline (driveway)
Front
rear
As you can see, the top of the rear tire is pretty much at fender level
