Suspension and brake questions
Hello everyone! I'm new to this forum. I have a 2005 Civic Canadian Si/American EX 4DR 1.7L
My suspensions feel so harsh, like it's one stiff rod that doesn't move.
I've been thinking of getting new quick struts for all 4 sides.
These are the struts I'm thinking about getting.
http://www.rockauto.com/en/moreinfo....430771&jsn=250
Are they good?
It would be really nice if someone could give me the torque specs for DIY struts replacements. One more thing, are there any other parts that I should replace while I'm doing my struts?
My brakes also needs replacing soon. I'd appreciate it very much if I can get a recommendation on ones that aren't too expensive but works for a daily driver.
I live in Canada as well so I can't buy from many online websites that only ship to the US.
Thanks very much!
Are they good?
Thanks very much!
Re: Suspension and brake questions
I can recommend Koni STr.T (orange): http://www.autoanything.com/suspensi...A5577A0A0.aspx You'll need a set of springs for them and they can lower ride height by: rear 1.5 inches and front 1 inch. That site list a kit too: http://www.autoanything.com/suspensi...0-lowering-kit Lowering it 1.5"s shouldn't affect ride quality and the benefit is better handling and (IMO) asthetics. You will not need a camber kit.
I had the STr.T's on an '07 Mazda 3 (replaced stock KYB2) and was surprised that they softened the ride even while lowering ride height. I don't recall them bottoming out and handling was much better than stock.
Koni STr.T video:
I have done a bounce test on all four sides but they all seem to be good. I believe these are the OEM struts from Honda. But it feels like it offers not even a bit of damping at all compared to any other cars I've been in. They are 12 years old. I see the Konis you recommended but I prefer to have a complete set so I don't have to mess with the springs.
Also, for brakes I want to switch out pads and rotors. Although my rear are drums which needs replacing too.
Thanks very much
Thanks very much
When it comes to suspension there's always a trade off of some sort between handling and ride comfort. The best balance between the two is generally met in high end cars such as BMW, Lexus, Mercedes, etc... Go-Karts are a harsh ride too but a lot of fun in the corners.
Brembo coated rotor: http://www.partsgeek.com/71zpc27-hon...ake-rotor.html
Bosch pads: http://www.ebay.com/itm/NEW-Bosch-BP...38.m2548.l4275
