My 05 civic have162,000 miles on it.
Old Mar 29, 2017
Darius340's Avatar
Darius340 is an unknown quantity at this point
It over heats after a period of time and I can't have it idling for maybe 15-20 mins..what can be the cause of this?? Bad gasket? Bad water pump?...every morning before I go work I always put coolant in it...I was told with that much mileage, I shouldn't waste my time on fixing the gasket? Is that true or not?
Old Mar 29, 2017
Re: My 05 civic have162,000 miles on it.
That's low mileage IMO. Unless it's an abused wreck or a rust bucket.
Why are you letting it idle for 15-20 minutes?
Where is the coolant disappearing to?
Word up: https://www.civicforums.com/forums/3...reference.html
Old Mar 30, 2017
Darius340's Avatar
No it's a good car....if I'm at a drive thru after 10 mins it will start too rise up buh, as soon as I start driving sometimes it slowly goes back down.
Old Mar 30, 2017
Darius340's Avatar
Old Mar 30, 2017
mikey1's Avatar
the first step is to find out where all this coolant is going, it can't possibly be burning that much if any at all,
what are you filling up? your rad or overflow?
are you putting in coolant or water or both?
Old Mar 30, 2017
Darius340's Avatar
I'm filling up my radiator. I haven't put any in my overflow for a whole now....I'm putting coolant in it
Old Mar 30, 2017
mikey1's Avatar
where is the coolant level at in the overflow bottle?
are you checking that also?
Old Mar 30, 2017
On the surface it's usually low coolant level and/or inoperative radiator fans.
The root cause is often much deeper, or, there may be a lot of 'cause and effect' that comes into play too.
You don't want to let Mr. Goodpliers hack a head gasket job either. You need someone who does good, thorough work.
The wrong person can total a car in just a few minutes (botched repair attempt causes more damage than the car is worth)
