Em2 random misfire
Old Mar 18, 2017
Em2rookie's Avatar
Em2rookie is an unknown quantity at this point
Em2 random misfire
I have a 2002 Honda Civic, I have owned it for a year now and ever since then I have had a random misfire. It had problems of over heating so it was rebuilt from the cylinder head up. The cylinder head got cut and cleaned it got new gaskets, new spark plugs, new EGR (was clogged with carbon) and after that still had a random misfire. So I decided to start from basics my friend got me used Honda ignition coils that he had laying around (same year and model) but didn't make a difference. Compression and fuel pressure checked out good and we're within specs , and at this point i don't know what path to take. Any suggestions? I have seen other forums for this same topic on the same model civic but no one has been able to figure it out Or even give a good direction on witch to go. Mostly every one gives up and passes it on
Old Mar 18, 2017
Em2rookie's Avatar
Re: Em2 random misfire
Forgot to mention it has new timing belt with tensioner and water pump. I have also replaced battery.
Old Mar 19, 2017
Post your fault codes and the freeze frame data
