Loctite on Cam shaft gear bolt Yes or No?
Old May 23, 2016
scooty's Avatar
scooty is on a distinguished road
Doing a head replacement. I've read some threads about cam gears coming loose. Is loctite necessary or should i just torque to 27 ftlb and call it a day?
Old May 23, 2016
Re: Loctite on Cam shaft gear bolt Yes or No?
Torque and call it a day. Haven't had a problem with my cam gear coming loose
Old May 24, 2016
If you don't trust, have your torque wrench checked first?
Medium strength Loctite?
Sup to you.
Old May 24, 2016
mikey1's Avatar
i used loctite last time but now im starting to regret it, i will be paranoid the next time i have to remove that bolt (hopefully never), my worst fear would be snapping the head off that bolt because the locitite, and the threads staying put inside the cam, or maybe i just worry too much
Old May 28, 2016
scooty's Avatar
Just heat up the bolt with a propane torch before removing it, the loctite will soften.
My torque wrench is pretty acurate. I'm just going to torque to spec with no loctite.
MyCivicDuties
General 7th Gen
Aug 21, 2019 03:31 PM
darthtony360
May 27, 2016 08:52 PM
Rwill060
May 24, 2016 09:38 AM
supersnake83
May 23, 2016 07:43 PM
alex_nyc
May 21, 2016 09:36 AM
