Buying a high mileage '03 Civic.
Hello,
Tomorrow I will be looking at a 18#,### mile 2003 EX. It is a two owner car according to the Carfax report. Owner says she has service records from her and the previous owner. The price is fair! Man, dealers want too much for old cars.
Anyhow, is there anything in particular notable about this generation of Civics?
She said the timing belt was done at 100,000 miles. I guess these aren't chains.
Re: Buying a high mileage '03 Civic.
If there are any issues it won't be with the model. At that mileage there will be issues on any make/model.
The head gaskets and automatic transmissions are prone to failure on some vehicles of that year. If the coolant is over full in the reservoir and/or low in the rad., be ware of head gasket issues. If there is any transmission hesitation/failure to shift do not buy the car.
It will definitely have lost compression (but if you are using it as a grocery getter, this is not a concern).
I can't imagine it does not leak/burn some oil. (if you do not want to have these issues fixed make sure to check oil level every week, then if everything is ok every two weeks, then monthly, then every two months and so on until you know the engine well).
Make sure to update all basic maintenance issues.
-Check mileage on all fluids
-check/change airfilter
-check/change spark plugs
-check battery health
then fallow Gearbox's DIY
https://www.civicforums.com/forums/1...e-up-mods.html
That is just regular engine wear and tear. The piston rings slowly shed metal as they pass up and down through the cylinders, or, the cylinders shed material from the block.
The valve seals also go and loose compression.
My car is only 170,000km old or 105,000 miles and I've dropped compression from stock 180-190 down to 150 across all four cylinders.
have the car scanned for engine codes etc
check the catalytic converter if it were replaced yet. thats a $900 dealer part.
whats up with the timing belt? it it brakes, valves could get bent.
frame rot or damage?
does the engine ID # match the car?
Exactly.
I'd imagine the deterioration is exponential to a point (where you loose the most amount of power at first then it teeters off), not a linear deterioration to absolute zero.
If I'm not burning oil and my valves are still closing tight, I can see compression being off from a new, tight motor, but Honda advises 5w-20 oil, or 0w-20. We are talking pretty tight tolerances. I don't believe my engine is down more than 5 horsepower from when it was new.
Hello,
Yours sounds broken, or maybe there are issues with your test equipment or method.
Spencer Morgan
Nov 20, 2015 12:02 PM
shriketheavatar
Oct 20, 2015 08:31 PM
