2001 civic shaking felt in the interior
Old Mar 20, 2016
Nalmonte's Avatar
Nalmonte is an unknown quantity at this point
Hello all,
Is it normal for 7th gen civics to shake on the inside when the engine is on.
I did have all four mounts replacedand new tramission as well but still shakes.
Changed spark plugs and coils.
Any other suggestions to fix the shakes.
Thank again for the help guys.
Old Mar 20, 2016
Poopies's Avatar
Super Moderator
Re: 2001 civic shaking felt in the interior
Is it just when it's idling or even when you're driving? You might want to consider cleaning the throttle body, idle air control valve and change your upstream oxygen sensor. I'm assuming your engine isn't showing a ?
Old Mar 20, 2016
Nalmonte's Avatar
Hey poopies,
No cel, I don't feel the shaking when driving but when I'm stopped i feel the shakes. Is the up stream o2 sensor the one on the header of the muffler body?
I was planning on cleaning the throttle body just was a good tutorial video to follow.
I clean out the egr valve a few week ago.
Thank you your tips.
Old Mar 20, 2016
Poopies's Avatar
Super Moderator
I followed the steps in this DIY last weekend:
https://www.civicforums.com/forums/1...e-up-mods.html
It took me about an hour to do. Yes, by upstream I mean the one connected to your header. It tells your engine to adjust the fuel/air mixture for optimum fuel burn. This can have a direct effect on how smoothly your car runs.
Old Mar 20, 2016
Nalmonte's Avatar
Thanks again I will try this after my state inspection later this week.
Old Mar 20, 2016
It is a machine. Noises and vibrations are normal for any machine that is operating.
Is it excessive or unusual? Compare to another similar car.
I did have
If you are the one dictating replacement parts, you may not get anyone working on the car who can actually figure out what your problem is.
Aftermarket mounts usually make it worse. Factory mounts are usually much softer than aftermarket.
There's also a procedure called 'neutralizing' that should be done so none of the mounts are in a bind.
Determine the root cause first.
The engine might shake normally, but if that vibration is transmitted into the car body through hard mounts or anything else attached to the engine making contact with the body, that would not be normal......
Noises/rattles/shakes/loose parts/rusted heat shields/hood vibration/etc.?
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
AnotherDopeStyle
Jan 5, 2002 06:39 PM
Micks2K1
Dec 10, 2001 07:11 PM
SpdRcrChk
Nov 15, 2001 11:33 AM
Rooskey
Nov 9, 2001 03:05 PM
