Wrong motor in my 2003 Honda Civic ex
Rep Power: 0 Wrong motor in my 2003 Honda Civic ex
I just got my 2003 Honda Civic ex engine replaced by this dum *** mechanic who put a d17a1 instead of the d17a2 so now I can't pass 4,000 rpm it's extremely annoying that I cant pass 80 mph. Can I just put on a d17a2 head on on the d17a1 block to make it pass 4000 rpm. And yes I have all the components for the vtec system
Re: Wrong motor in my 2003 Honda Civic ex
It can be done AFAIK.....but the D17A1 has lower compression than the A2, so keep that in mind.
Is the original engine wire harness is still intact? (connectors for the VTEC are still there and disconnected)? There are several differences in engine wiring harness from A1 and A2 engines.
Received 1,156 Likes
Rep Power: 486 Re: Wrong motor in my 2003 Honda Civic ex
Yeah, the -a2 head/-a1 block combo has been done, mostly for turbo setups due to the lower compression, just gotta check if the mechanic used the -a2 harness, like ezone said.
Rep Power: 0 Re: Wrong motor in my 2003 Honda Civic ex
The mechanic just bought the motor and that's it he used the Same wiring harness he mounted everything what a a2 would have on
and yeah he connected everything for the vtec
What happened to the rule about the seller having to smog the car before sale? This would never pass smog test, by visual nor by codes.
Straight up swap if you use the correct stuff. New head gasket and manifold gaskets, fluids and whatnot.
Off the top of my head, EGR valve and intake manifold gasket (1 extra hole for EGR port) are the other differences between the A1 and A2 engines
for 01-03, only D17A2 used EGR
04-05, D17A1 and A2 both used EGR.
Does your current setup have the EGR valve in place?
So I just installed it the vtec head and everthing on it and it's still doing the same thing still cuts me off at 4K (limp mode) and same code still pops out vtec system failure what else can it be need some help on this getting kinda annoyed on this lol
What code does it have?
Does the vtec solenoid work?
Does the vtec valve work?
Does the vtec pressure switch work?
Got oil pressure?
Got oil pressure loss?
You got a rebuilt head or something for it?
Is the short bolt missing from the oil passage in the head?
See this thread:
https://www.civicforums.com/forums/36-mechanical-problems-vehicle-issues-fix-forum/351958-missing-bolt-causing-p1259.html
Got oil pressure?
See this thread:
Got oil pressure?
See this thread:
Got oil pressure?
See this thread:
jdawgzcivic
17
02-01-2020 04:16 PM
chiquita.banana
09-24-2015 09:42 AM
