Jdm d17 help with vtec
Old Jan 20, 2016
05civixlx's Avatar
05civixlx is an unknown quantity at this point
Ok so I Got a 1.7 d17 from Japan with the ecu all sensors are the same other then the vtec how do I make it work where do I hook up the vtec wire
Old Jan 20, 2016
Re: Jdm d17 help with vtec
Swap the original VTEC pressure switch into the new engine.
Old Jan 22, 2016
05civixlx's Avatar
So my civic is the 1.7 non vtec Jdm engine I got is vtec with the ecu do I just plug the Jdm ecu to my wiring harness and where do I hook up the vtec solenoid wire to
And another question can I run and drive my engine for a long time with out the vtec solenoid with out hurting the engine
Old Jan 22, 2016
If using the original wire harness for a non-VTEC engine, now you will have to run a new wire to operate it...and you'll need a correct terminal/pigtail to install in the PCM connector for it.
Does this new engine use a knock sensor where the old engine did not?
dabatman99
35
Feb 16, 2016 07:11 PM
1hondacivic1
Jan 18, 2016 10:06 PM
Niaboc67
Jan 18, 2016 06:25 PM
cscounts
16
Jan 17, 2016 01:35 PM
