NEW (to me ) '01 Civic EX.....Help?
Old Dec 20, 2015
Ndnboy's Avatar
Ndnboy is an unknown quantity at this point
Newbie here, just picked up an 01 Civic EX with 110K for my son. First car for teen driver and would appreciate any insights from the forum.
- came with 1 key, anyway of getting a spare made without stealer stealership pricing?
-Any issues to look for? I've seen numerous trans issues, think I have a clean one, time will tell.
- oil looks clean but plan on changing anyway to start a new clock. Not knowing prior maintenance, should I look at doing plugs, ATF, etc.......
Thanks for any input....hope to look around DIY items......want him to have a safe and reliable ride.
Old Dec 20, 2015
Re: NEW (to me ) '01 Civic EX.....Help?
read teh stickies on the top of each section of the forums - they have lots of useful information, being the reason we stickied them there.
the key is codes to the ECU (anti-theft system), dealer is the only option.
Old Dec 21, 2015
maxtierney's Avatar
EM2ti
You can go to Lowes and get a transponder key cut/programed for around $30. Some Ace Hardware stores can do it for $70.
Old Dec 21, 2015
Thanks, max, was not aware. Would programming still be done at dealer?
Old Dec 21, 2015
Ndnboy's Avatar
Thx, stopping by Lowes today and will check on key....
Old Dec 21, 2015
An Immobilizer Type 1, 2 or 3 key can be 'cloned' if one can find a place that has the equipment to do it.
All you need is one valid working (original?) key they can copy on the cutting machine and read the immobilizer info and burn it into a blank, programmable key (the cloneable keys from Ilco/Honda were stamped T5).
The car itself is not needed except to verify the new keys work correctly.
Old Dec 21, 2015
Ndnboy's Avatar
Stopped in at Lowes and $30 did the trick....the 1 dealer I called said it would be $50.
Shopping list so far:
Cabin filter 2
Air filter
Oil change (30W?)
With 110K and unknown maintenance record think I should do Spark Plugs and ATF drain/fill.
Looked at Majestic and seems like a good spot for some savings.
Anything I'm missing. ....
Old Dec 21, 2015
PMI's Avatar
PMI
PMI has a spectacular aura aboutPMI has a spectacular aura about
I bought one with similar mileage recently. My big service items were the timing belt and ATF. If you take a close look at the service schedule, both the timing belt and the transmission fluid have a service interval stated in miles, OR number of months, whichever comes first.
I also found broken sway bar links, both front and back, and a bad bushing in one of the lower control arms.
From what I am reading here my front suspension will need a thorough going over sometime soon.
You might also tell your son to handle the hood and fuel door release gently until he has a chance to lubricate the ends of the cables. My fuel door release came broken, and although there is a kit to fix that fairly easily, lubricating the cable ends is probably even easier.
Old Dec 21, 2015
Oil change (30W?)
Really?
The oil cap does not say anything 30 on it.
It says 5w20.
What oil was used again?
Yes, use the correct NGK or DENSO plugs.
And timing belt as mentioned if it has not been done recently.
Brake fluid, coolant, etc.
Majestic is one of many dealers selling online at wholesale prices.
Watch out for the shipping fees, they can negate any savings on small stuff. Math carefully.
Old Dec 22, 2015
Ndnboy's Avatar
Wasnt sure if it was 5w30.
Found NGK Iridium IX and Denso IK20 listed on other older threads, still the Best option for plugs?
Found Amazon has some free shipping on items that make it a bit more attractive, will def shop around to Math carefully, thx.
Old Dec 22, 2015
Hondas parts catalog calls for
DENSO: PKJ20CR-M11
or NGK: PZFR6F-11
m.colley
Jul 20, 2015 04:48 AM
Spanky4269
Jul 5, 2015 09:40 PM
emich
Jul 4, 2015 09:11 AM
pimpedcivic
40
Jul 23, 2002 11:41 PM
civicPesek
Nov 7, 2001 11:33 PM
