ATF Fluid
Old Dec 2, 2015
Deven Prasad's Avatar
Deven Prasad is an unknown quantity at this point
ATF Fluid
Hello Everyone!
I have a 2003 Civic with 271000KM and a Automatic Transmission.
I did a Drain & Fill Today, I think i may of overfilled it.
Attached is a photo of where it is reading on my dipstick.
Is there any consequences of being overfilled in this amount.
Old Dec 2, 2015
Re: ATF Fluid
Did you check it with the engine running, or engine off?
Old Dec 3, 2015
mac25's Avatar
Dr Krieger of Modification
Re: ATF Fluid
...as E is getting at these vehicles are a dead check, so you check them while on a flat surface and engine off.
Old Dec 3, 2015
mac25's Avatar
Re: ATF Fluid
You should probably adjust it, if it is indeed overfull.
Old Dec 3, 2015
Re: ATF Fluid
Fluid level check is supposed to be done on a fully warmed up trans, and within 90 seconds of turning the engine off.
Honda is the only company I know of that wants their ATF checked while the engine is not running.
Old Dec 19, 2015
mikey1's Avatar
Re: ATF Fluid
Originally Posted by Deven Prasad
Hello Everyone!
if you checked the level properly, warm transmission and engine not running, then that level is WAY too high, i would definitely drain some to get it within the correct high/low level,
overfilling is just as bad as underfilling,
anywhere within the high/low marks is fine
burnyd
ECU Fried
May 24, 2018 10:44 PM
GotSiR
Mar 8, 2017 05:33 PM
redcloud
25
Aug 12, 2015 01:23 PM
jedi
Aug 3, 2015 04:26 PM
mcollins
Electrical
Jul 27, 2015 10:59 PM
