reverse lights hell
Old Mar 1, 2015
Doug Lassiter's Avatar
Doug Lassiter is an unknown quantity at this point
reverse lights hell
Civic LX 2003. OK, I'm at my wits end. I was checking all lights before inspection, as I usually do. Reverse lights, OK. Emergency lights, OK. Brake and tailight, OK, except on left side. Neither worked on that side. No sweat. That 7443 bulb had both filaments burned out. Replaced that bulb, and brake and tailights now all work. BUT, now the reverse lights don't. They just stopped working. WTF? I *think* the reverse light is fuse 19, and that seems fine. What am I missing??? Does this have anything to do with replacing the tail/brake light?
Old Mar 1, 2015
CraigW's Avatar
Re: reverse lights hell
Fuse #10 7.5A under-dash box.
Old Mar 3, 2015
Well, OK. This was weird. After all that, the backup lights started working again. All fine. Is this how the backup light switch fails? Gotta keep my eye on this thing.
Old Mar 3, 2015
If it's a sedan with the back up lights in the trunk lid.......
Make the backup lights stay on then go open the trunk lid slowly a few times while watching the lights. If they go out as you open or close the trunk, then you probably have a broken wire in the harness at the hinge area.
Poopies
Apr 20, 2017 11:36 PM
Blazz
Jun 4, 2015 01:04 AM
Richkid23
Apr 19, 2015 12:53 PM
mwwhonda
Nov 30, 2001 08:44 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
