misfire
Old Dec 16, 2014
Wozzy's Avatar
Wozzy is an unknown quantity at this point
misfire
I have a 2005 Honda Civic. It's been having a misfire code come up on cylinder #2 since August. I had a tune-up done they even replaced #2 spark plug twice, all coil pacs check good I had the EGR ports cleaned and I had them replace the #2 injector. Any suggestions I am going crazy.
Old Dec 16, 2014
Re: misfire
Please post the freeze frame data that goes with the code.
How was this done?
tune-up done they even replaced #2 spark plug twice, all coil pacs check good ......
...and I had them replace the #2 injector. Any suggestions I am going crazy.
When's the last time the valves were adjusted?
Compression test results were....?
Old Dec 16, 2014
Wozzy's Avatar
Re: misfire
All this work was done at a Honda Dealer don't had the info.
Old Dec 16, 2014
Re: misfire
I assume you paid for accurate diagnosis and correct repair?
Sounds like they aren't finished and it needs to go back to them.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
