new owner, funny noise
Old Sep 26, 2014
petept's Avatar
petept is an unknown quantity at this point
Hello all, just picked up a 2001 civic 5 speed with 140,000. Great shape but I hear a little cluncking sound from passenger side front on bumps . All tie rod ends, ball joints, swaybar end links, all looks good, no play in the wheel, or steering wheel. Drives great, but confused. Owner provided me with all maint. Reciepts, showing, oil changes, new tires, brakes, timing belt and water pump. All done in the last 10,000 miles. What do ya all think? Also is it a good idea to swap out the manual trans fluid? Thank you all for all the help.
Old Sep 26, 2014
mikey1's Avatar
Re: new owner, funny noise
what do i think?
i think its pretty normal for a 14 year old car to make a few strange noises,
you cant go by looks, its not like a woman
strut, strut mounts, control arm bushings, sway bar link, lower ball joint, tie rod end, cv joint/drive axle
your problem lies within one or more of these items
Old Sep 26, 2014
cja3455's Avatar
cja3455 is an unknown quantity at this point
try jacking up the car and hit the tire with a hammer and see where the sound is coming from
Old Sep 26, 2014
funny noise
My sick mind thinks you may have run over a clown who is now trapped under the car.
Old Sep 26, 2014
GolNat's Avatar
Prelude Owner
Sounds like a strut mount...or a clown.
Old Sep 26, 2014
Kennykid2002's Avatar
Kenny the Ricer
CV joint and axles been looked at?
Old Sep 26, 2014
petept's Avatar
Cv boots look new and clean. Axles tight, no movement at the wheels. As long as its safe im not to worried. Drives great just this weird clunck clunck over bumps at the one side. I wonder if a new set of struts would do it?
Old Sep 27, 2014
mikey1's Avatar
stop using the word "look"
check things out properly,
Old Sep 27, 2014
Or take it to someone who can.
The struts sometimes don't have outward indications of a problem (no obvious leakage or anything), but make noise due to an internal problem...
Sometimes you just have to eliminate everything else as a possible cause.
One typical failed strut noise was a clunk that would happen when rolling across a 0.5inch pavement pad rise, like when I roll a car into the shop the concrete pad of the shop floor is about 0.5 inches higher than the outside pavement, and as I drive a car in through the doorway--- CLUNK
Not saying that's your problem, just giving an example.
Old Sep 27, 2014
usajags84's Avatar
usajags84 is an unknown quantity at this point
I know you Came looking an exact answer but it's one of those it might be best to have it checked by a pro. I have a history of doing things the hard way Some places will give you a estimate however whatever you do don't replace a strut without a strut mount... I've leaved this the hard way Did you look at your lower control arm bushings?? Check out this great DIY https://www.civicforums.com/forums/1...-bushings.html also a lot of stores sell complete strut spring for the DIY user to change includes the spring strut and mount I assembly's and front end kits I was pricing doing mine for 149 both front struts and 115 lca arms tie rod ends and ball joints and sway links. Doing all the work myself then bringing for an alignment
If you change anything your self please make sure you torque to spec use jack stand and ask for help if you need it.
In regards to your question about it being safe... It's a older car things get wore out and should be replaced as needed...
Not trying to sound like the old man on the forum but if something is banging or clanging it has play... If you needed to swerve fast or correct a turn could the play become a factor in your ability to avoid a collision...
Also if a pro checks out your car it might cost a little but then you have an educated opinion on the problem and if the solution fits your budget
Old Sep 29, 2014
rezsst's Avatar
rezsst is an unknown quantity at this point
I've been using brakes plus..free inspection and $50 alignment. Jst have them inspect it and you do the work then return for an alignment if needed .if you Jack the front tire up about an inch of ground then stick a pry bar or board and pry up looking to see what's lose. I put my hand on ball joints to feel for slop. Any more then a 2/16" needs replacement. Have someone in the car turning wheel left n right while you check front steering. There's plenty of how to videos on YouTube.
Old Oct 5, 2014
petept's Avatar
Well, thanks for the advice.Turns out I had a bad sway bar bushing, I felt a little movement in there. Got both new ones and........beautifull, very nice, tight and quiet. I look forward to getting to know you all as I begin my life with my new to me civic. I will post pic if I figure it out.
Old Oct 5, 2014
Kenny the Ricer
How did ya go about finding it?
Shaking every movable part?
Old Oct 6, 2014
petept's Avatar
Laying under car, swaybar bushings looked rotten, hard, and just weird looking, installed both new ones with moog parts and it is best it has ever been.
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
15EXCoupe
Jul 30, 2015 12:59 PM
mokkush
Jul 14, 2015 04:05 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
