side mirror glass size
Old Apr 23, 2014
wcu25rs's Avatar
wcu25rs is an unknown quantity at this point
So my wife was backing out of the driveway and the side mirror glass just fell off and shattered. The mirror backing is still in place so I just need the glass. Rockauto shows a 7 3/16" flat glass and a 7 1/16" flat glass. This will be going on a 04 Si. I doubt a 1/16" would make a difference, but technically, what is the correct size? Thanks!
Old Apr 23, 2014
CraigW's Avatar
Re: side mirror glass size
Get it from dealer, it should pop right in place into holder.
Old Apr 23, 2014
Poopies's Avatar
Super Moderator
Yeah, it's only 40 bucks. Depending on the side it's either part 2 or 7 here.
So your wife told you it just fell off all by itself, huh?
Old Apr 24, 2014
wcu25rs's Avatar
no it totally did. She was leaving to go to work, I was still in the house. I heard glass break and thought "oh great, she backed into my WRX." Went out, and there it was, on the ground. The car has 112k on it, and I'm not sure how it stayed on this long. the mirror didnt have any adhesive and the little plastic backing, that I assume is attached to the motor, had none on it. Glad it came off in the driveway instead of on the highway.
Forgot to mention, Rockauto has it for around 17 bucks. I'll avoid the dealer if at all possible. Just wanting to know what the correct size is, or if even a 1/16" would make a difference.
Old Apr 24, 2014
Poopies's Avatar
Super Moderator
I'm not sure about the size... I guess you can get a ruler or something. It would be a shame if the thing was too wide to fit or adjust properly. I'd probably go with the smaller one to be safe. For the record, I'm glad she didn't back onto your Subaru.
Old Apr 24, 2014
CraigW's Avatar
There should be clearance for that tiny bit larger.... and the plastic clip on the back will set the spacing.
Good price, never checked oem $$
Old Apr 28, 2014
wcu25rs's Avatar
yeah me too!
thanks for the help guys!
Erndog81
Oct 31, 2015 03:01 PM
SugarRay
Dec 6, 2001 05:17 PM
genterara
Detailing
Dec 1, 2001 04:05 PM
