Redline MTL vs Amsoil Synchromesh
Old Mar 9, 2014
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Any opinions? Would love shifts to feel a little smoother.
Old Mar 9, 2014
Poopies's Avatar
Super Moderator
Re: Redline MTL vs Amsoil Synchromesh
I'm not too sure that can be achieved on a Honda transmission
Old Mar 15, 2014
sl33pyriceboi's Avatar
I just GM synchro mesh friction modified. It's butter smooth.
I also have a revo short shifter with solid aluminum bushings
Old Mar 15, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
^ Agree. One of the few good things to come out of GM is their diff and synchro fluids, very good stuff according to a lot of different sources with lots of different applications. One racing buddy even uses it in his CRF450R gearbox (doesn't share engine oil)... and loves its 'velvety' feel slotting in the dogs under power. No signs of shear as long as he uses the OEM change interval (he also has a Trailblazer SS, so one-stop shopping for him)...
How expensive is that stuff, though? The diff fluid is ungodly pricey and/or hard to get IIRC. Honda's trans oil lasted over ten years without sacrificing shift quality, so unless the GM synchro fluid puts it a notch above that (hard to imagine), the high cost:benefit ratio will keep OEM Honda fluid in my car...
There are those that swear by super-cheap ATF in a manual trans. To which I say, show me a magnetic plug after 50K in *your* trans, and I'll consider it. ATF's only advantage is tons of detergent to keep sludge from forming and adhering under high heat and pressure. Keeping material from coming off the gear tooth faces is crucial in a manual trans which has little of the same heat and pressure problems as in a slushbox.
Old Mar 19, 2014
got2run5's Avatar
After researching a crap ton, here is what I came up with.
-GM: Great stuff, pretty cheap, unfortunately they stopped making that formula.
-Amsoil: Best stuff when new, some said it faded after around 5k and wasn't so great when it was cold but once heated up worked well
-Redline MTL: Some said they didn't see much difference but there wasn't anything bad so I tried it. I'm pretty pleased with the result-super smooth shifts.
Old Apr 11, 2014
avenger's Avatar
avenger is an unknown quantity at this point
redline
Old Apr 11, 2014
kinakoes2's Avatar
144K on this EX manual so far... and with OEM fluid only, seems to do okay. I need to swap axles soon, which will help with unwanted bearing load and help shift accuracy. But I'm sticking with the OEM fluid unless there's an undeniable advantage.
SidCivic
44
Oct 12, 2017 03:39 PM
cferry7
Oct 3, 2015 04:33 PM
dantheman42
Sep 4, 2015 01:10 PM
Nuts
Bolt-on Engine Performance
24
Sep 25, 2002 07:25 AM
Silvic02
Mar 22, 2002 09:09 PM
