Tein S Tech on Civic 03 Ex, will the back sag?
Old Oct 30, 2013
Nardo19's Avatar
Nardo19 is an unknown quantity at this point
So I got the Tein S Tech springs & I'm about to install them but before I do I want to make sure the back won't sag. I've looked all over the place & can't find any pictures of 03 Civic Ex Sedans with S Techs on em? I want a nice even look, 1.5'' drop in the front & in the back. Anybody got pictures or info???
Old Oct 31, 2013
rustycivic's Avatar
rustycivic is on a distinguished road
Re: Tein S Tech on Civic 03 Ex, will the back sag?
Why would the back sag? Do you have 300+ lbs of stuff in your trunk? I'm pretty sure Tein designed the springs to have a pretty even drop.
That being said, are you replacing your shocks at the same time?
Old Oct 31, 2013
GolNat's Avatar
Prelude Owner
It doesn't sag, it gives the illusion that the drop is uneven because the wheel gap in the back is smaller then the front. It's more noticeable when the car is dropped because there is less of a fender gap. Yes the springs drop the car an even amount but at stock ride height the fender gap in the front is larger then in the rear. Springs with a larger drop in the front will even it out more.
Now strut choice may make a difference depending on where the spring perch is located. I know Koni's you can move the spring perch so you could potentially use that to even the drop out. I had Tokico D-Specs with Sportline springs (1.5" drop) and my sedan sat lower in the rear.
Old Oct 31, 2013
Nardo19's Avatar
No major weight, just 2 12" alpines. But I heard it might look uneven since it's a sedan.
Old Oct 31, 2013
Nardo19's Avatar
Thanks for the picture & the quick reply, that's exactly what i was looking for! I'm going on OEM struts for right now. Maybe putting a rubber spacer will make the back even with the front.
Old Oct 31, 2013
GolNat's Avatar
Prelude Owner
Yes the rubber spacer will work. I was going to do that, but then I bought coilovers.
I was on OE struts for a week or so before ordering Tokico's and it sat at the same height in the rear with both. I think you can get the rubber spacers from local parts stores.
Old Oct 31, 2013
Nardo19's Avatar
Yeah, I got some spacers already so I'm going to try it & see how it comes out. Thanks man!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
usajags84
15
Aug 19, 2015 03:12 AM
bsmiley
Apr 27, 2015 01:27 PM
Russps
Nov 8, 2001 02:00 AM
