Sponsored by:
Sponsored by: DashLynx
Transmission Cooler Add-on -Drivers side or
Old 09-20-2013
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
2003 civic ex coupe auto transmission.
I seen some threads about Auto Transmission Coolers but they say install on right side. Your right side or My side???
So which Transmission connection gets the cooler? - Drivers side or Passenger side connection? or does it really matter?
Thanks for your help.
alex_nyc is offline
Old 10-09-2013
alex_nyc's Avatar
Re: Transmission Cooler Add-on -Drivers side or
any trans cooler info out there?
alex_nyc is offline
Old 10-10-2013
Left and Right are ALWAYS determined as you sit in the drivers seat.
Left and right on any vehicle are always the same no matter where you are standing.
Make sense now?
ezone is offline
Old 10-10-2013
alex_nyc's Avatar
Make sense now?
ok thank you!
as per this post the cooler gets connected to the right side hose(passenger side) correct?? This is the pressure side?
https://www.civicforums.com/forums/1...ics-added.html
alex_nyc is offline
Old 10-11-2013
I can't get any pics in that old thread.
Short answer for me is that I can't ever remember which is which on the trans, I have to follow the lines on the bottom of the radiator. Problem is that the lines can cross between the rad and trans, so looks can be deceiving.
My answer would be that the return is the line connected to the drivers side of the radiator cooler, so the pressure line is the one going into the passengers side of the radiator bottom tank. Carefully follow the hoses from there.
Easiest positive check would be to simply disconnect a line and crank the engine. See which end blows fluid out.
If you connect an additional trans cooler in series with the original cooler (the one inside the radiator) I suppose the plumbing connection point chosen would depend on whether or not you want the original cooler to still act as a fluid warmer in cold weather.
ezone is offline
Old 10-11-2013
Just sent PM to gearbox, let's see if he can clarify what was in his old thread.
ezone is offline
GolNat
Suspension DIY
05-12-2022 06:49 AM
RIPSAW
11-06-2015 04:36 AM
Lopes101
06-07-2015 08:04 PM
Thriftmaster
Vancouver
04-28-2015 06:02 AM
bsmiley
04-27-2015 01:27 PM
Quick Reply: Transmission Cooler Add-on -Drivers side or
