"forgotten tune-up" help
Old Apr 19, 2013
botakcivic's Avatar
botakcivic is an unknown quantity at this point
First, i would like to thank gearbox for his great write-up.
Attempting to clean my pcv valve and was unable to remove the lower part of the airbox....can someone advise please?
Thank you.
Old Apr 20, 2013
mikey1's Avatar
Re: "forgotten tune-up" help
im not sure why you need to remove it, i replaced my pcv valve without touching the airbox,
but to answer your question, there is basically a big "hose clamp" that goes around the throttle body, you need to loosen that then just pull up on the air box,
you need an 8mm socket with an extension to get in there
Old Apr 20, 2013
botakcivic's Avatar
Thank you!
Got it.
Remove to get to throttle body.
Appreciate the help.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
h4ldol
Jun 28, 2015 10:18 PM
CivicVoz
Apr 16, 2015 08:07 PM
