Just got a 2003 Honda Civic with 176,000 miles, how can I keep it going?
Old Feb 28, 2013
Dranixger's Avatar
Dranixger is an unknown quantity at this point
Yep, just bought a 2003 Honda Civic, and it has relatively high mileage. I know Civics can last for well over 300,000 if they're taken care of properly, so what are some tips you'd give me to achieve that? What kind of oil to use, any other additives or fluids you'd recommend, what kind of maintenance to perform when, etc.
Old Feb 28, 2013
Stock 99's Avatar
Re: Just got a 2003 Honda Civic with 176,000 miles, how can I keep it going?
Use the proper grade of oil for the car (doesn't matte what brand), do regular maintenance as described in the owners manual and don't put additives of any kind in your engine.
Old Feb 28, 2013
Tragedy's Avatar
skate or die
Timing belt asap.
Honestly if you just dropped the cash on the car, you already made a decision to refurbish it.
I did as well.
Bust a band on your cash roll and get that timing belt, water pump, tensioner, tensioner bolt, alternator belt, ps belt, new starter, alternator, air filter, fuel injectors, evap filter, spark plugs, and so on. Get it done.
Old Feb 28, 2013
drmcstford's Avatar
Civ ILL
drmcstford is an unknown quantity at this point
I didn't go that extreme , but I did do Head gasket kit, water pump, timing belt, timing belt tensioner, timing belt, radiator, thermostat, and rad cap. Car runs seriously like new. Now i'm fixing the front bumper, fender and hood they need new paint :/
Old Feb 28, 2013
scooty's Avatar
scooty is on a distinguished road
Not sure 7th gen Civics last 300K miles without at least 2 head gasket jobs, and maybe a transmission job as well.
Old Mar 5, 2013
fsckewe's Avatar
fsckewe is an unknown quantity at this point
Originally Posted by Tragedy
Timing belt asap.
I did as well.
wow
A few drain and fills of the tranny is probably a good idea.
OP, did the previous owner give you service records? When was the last time the timing belt was done? Timing belt is a good start for inquiry. Buy a service manual, they are cheap. If you have no maintenance history start going thru all the maintenance items listed in the front. Don't just blindly start replacing ****.
Old Mar 5, 2013
DeamonG37S's Avatar
DeamonG37S is an unknown quantity at this point
u cant with 7th gen civics.
Old Mar 5, 2013
scooty's Avatar
Up to a 96 Civic you probably can easily. What gen is that?
Old Mar 6, 2013
mikey1's Avatar
i dont agree with that.....
my 2005 is at 220,000 with no tranny or head gasket problems....runs and shifts like new....in my opinion, the lifespan of the head gasket and tranny are determined by how the vehicle is treated and driven....my car rarely ever sees RPM's over 3,000.....just sayin
Old Mar 6, 2013
DeamonG37S's Avatar
VTECH doesn't even kick in at that rpm range y buy the si if u can't hit vtech w/o breaking sumfin. 7th gen are 2001 to 2005. I think the strongest motor honda made was the SiR 6th gen. Yea pretty much u gotta baby the 7th gens, vtech at your own risk lol. Still a great car imo.
Old Mar 6, 2013
BlueEM2's Avatar
Whachya lookin at?
Not revving your car properly can be more damaging than revving it too much. There is a fine line you have to be in for the car to be healthy. Revving 1500 going uphill trying to accelerate is causing the engine to work very hard if you know what I mean. These engines are desgined for higher RPMs just look at what you pull going 60 MPH on the highway. Also, if you keep your revs too low you build up carbon at a higher rate because things just don't flow as smoothly.
Old Mar 6, 2013
scooty's Avatar
You rarely go over 3000? Do you "Prius" your car at 65 mph down the interstate?
I'm easily doing over 3000 rpm at 75 mph just keeping up with traffic.
With 3 passengers in the car it's almost impossible not to hit 4000 rpm before shifting while merging into faster traffic.
I do agree that keeping below 3000 will most definitely extend HG life. I just find it difficult to drive like that.
Old Mar 7, 2013
mikey1's Avatar
i said rarely....obviously their are exceptions....getting onto the highway, passing, etc etc....i was more talking about "light to light" city driving
Old Mar 7, 2013
mikey1's Avatar
not sure what tranny you have, but im only at 2700-2800 RPMs at 75MPH
Old Mar 7, 2013
DeamonG37S's Avatar
This is all correct. This is stock numbers; increase this it helps HP (hp@rpm)127 @ 6300Torque (lb.ft@rpm)114 @ 4800 more power thru-out the range. Engine runs more efficient with some bolt on mods.
vtec92
May 4, 2017 03:20 AM
jessicakaybby
Apr 20, 2015 12:11 PM
inarschenk
South
Apr 18, 2015 04:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
