Oil Leak
Oil Leak
I have a 2004 Honda Civic EX and it looks like it is leaking a little oil from behind the crankshaft pulley next to the oil pan. Can I fix this problem with a new seal or do I need to take it to a mechanic?
Re: Oil Leak
Sounds like the crank seal, which is a PITA if you've never done a timing belt. While they're in there have the timing belt, water pump and tensioner done as well since they'll have to remove the belt to fix the seal.
Re: Oil Leak
could be a number of things.....most common would be crankshaft seal or oil pump gasket/seal, it could also be your camshaft seal and the oil is dripping all the way down the timing area....you are going to need to remove the timing cover to inspect it
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
Kyrian
Jun 26, 2015 11:48 AM
671civicLX
Jun 13, 2015 05:56 PM
