Inner Pipe Exhaust Crack - Vibration
Old Nov 28, 2012
ThoseGuys's Avatar
ThoseGuys is an unknown quantity at this point
Hi folks. First timer, here it goes. I have an 02' manual LX. It recently developed a relatively high pitch rattle/vibration at approx 25-2700 rpms. I jacked her up and had a buddy bring the rpms up and it seemed to be rattling right where the pipe comes out of the cat. I unbolted it and inspected and what I found is a pretty big crack in the inner pipe (pipe within the pipe) right at the first little bend. I am wondering if anyone has ever seen this and if anyone has any solutions other than the obvious replacement. Here is a picture. Thanks for the help.
Name:	honda pipe crack.jpg
Old Nov 28, 2012
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Re: Inner Pipe Exhaust Crack - Vibration
Do you have a flex pipe? Spring bolts where your header connects to your down pipe? And also what kind of exhaust is it? Bought it off of eBay?
Old Nov 28, 2012
ThoseGuys's Avatar
Stock pipe. Spring bolts. Comes directly off the cat. Thanks for the quick response.
Old Nov 28, 2012
SlimRisk's Avatar
Busy Speeding!!
That's really weird. Make sure all the connections and rubber hangers are in good condition. Does your engine shake more than normal?
Old Nov 28, 2012
ThoseGuys's Avatar
It doesn't shake abnormally. Hangers seem to be fine. It just started vibrating one day and although I didn't know for sure if there was an inner pipe that was my initial assumption when I heard it from underneath the car. Sure enough when I looked inside there is that big ol' crack....
Old Nov 29, 2012
ThoseGuys's Avatar
If anyone else could chime in here I would really appreciate it.
Old Dec 1, 2012
scooty's Avatar
scooty is on a distinguished road
That sucks! Don't think it can be repaired. Just buy new pipe.
I just replaced that whole pipe for like $80 from Rock Auto. It's all one piece from the cat all the way to the muffler at the back. It comes with a new resonator as well. Pretty easy to replace. You are half way there already. There are just 2 more spring bolts at the muffler joint and the part drops out. just make sure you order new spring bolts and doughnut gaskets.
cukaracha
Aug 27, 2015 02:02 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
Theshwartz35
Jul 17, 2015 11:13 PM
hayden55
Jul 8, 2015 11:38 PM
Causemo
Jul 5, 2015 06:42 AM
