05 si burning oil
Old Nov 21, 2012
DEZZIE41's Avatar
DEZZIE41 is an unknown quantity at this point
Question 05 si burning oil
Think my si is burning oil checked it today and was down a but and I just did oil change on sat what should I look for or how to correct this thanks
Old Nov 21, 2012
mikey1's Avatar
Re: 05 si burning oil
how much could it possibly be down in 4 days?
how far have you driven since?
Old Nov 24, 2012
MonKy's Avatar
MonKy is an unknown quantity at this point
i have the same issue :/
Old Nov 24, 2012
sl33pyriceboi's Avatar
Try switching to valvoline maxlife oil
Old Nov 25, 2012
Randomhero's Avatar
Randomhero is an unknown quantity at this point
Stop using Mobil 1. Try Pennzoil Ultra or Valvoline Synthetic MaxLife. Also use a Purelator PureOne filter, they are boss.
On a side note, it is likely that it wasnt filled up enough. Some people disregard even the most basic OC procedures. Make sure the car is parked on a level surface for at least 10min- 1hr before checking it again. Personally, i check mine in the morning after sitting over night.
Old Nov 25, 2012
mikey1's Avatar
this is incorrect,
oil should always be checked when the engine (and oil) are warm (full operating temperature), turn the engine off and wait about 2-3 mins, then check your oil, this is when you get the most accurate reading, you dont want all the oil down in the pan,
Old Nov 25, 2012
GolNat's Avatar
Prelude Owner
It''s normal for cars to burn oil, just depends how much. You can go to a slightly heavier weight also.
Old Nov 25, 2012
cb450sc's Avatar
cb450sc is an unknown quantity at this point
Are you running 5W20? If so, try a 5W30, 10W30 or a 5W40.
brags
46
Jan 7, 2016 09:39 PM
emich
Dec 11, 2015 12:20 PM
1khilari
Jul 9, 2015 08:12 PM
