1.
i have a honda civic lx 2002. when i turn the key OFF ( II), the door automatic lock, and when i turn the key OFF ( I), the door automatic unlock. so i want to disable that program, someone please help me.
-I tried follow this construction, but it doesn't work
http://www.8thcivic.com/forums/insid...auto-open.html
-I have done with Google search about this issue, but all of them don't work.
=> i really really mad with issue, someone please help me please
2.
i lost the the remote transmission, so i bought a new one on ikeyless.com. and i tried follow their construction, but it doesn't work ( maybe cause the automatic lock and unlock when turn key ON and OFF). please help me.
2.
Your car is not equipped with automatic locking from the factory.
Someone has had that installed, it is aftermarket.
You will have to get under the dash, find the aftermarket unit, and disconnect it.
Then you will have to figure out if the car is actually equipped with keyless entry, either factory installed (EX) or dealer installed (LX and below).
Check out this thread too. https://www.civicforums.com/forums/3...ml#post4617206
HTH
HTH
HTH
how can i know is factory's or dealer's or aftermarket's keyless entry when i see it?Originally Posted by ezone
Your car is not equipped with automatic locking from the factory. Someone has had that installed, it is aftermarket.
HTH
If you look under the dash and it looks like a rats nest of wires staring at you, you can probably assume it isn't factory.how can i know is factory's or dealer's or aftermarket's keyless entry when i see it?
LX didn't come from the factory with keyless. It would have to have been dealer installed if it has it.
Read that post I linked in my last reply to you. The thread too, but mainly that one whole post. Your answer should be in there.
Maybe it is time for a professional to have a go at it if you can't figure it out.
Everytime i start my car or even put the key in Ignition II, the doors auto lock everytime. Very annoying. So I have to unlock it every time. Wish i could disable it, i have Black widow alarm/remote starter.
Quote:
Google it if you don't have the manuals.Originally Posted by Civicnoobie
, i have Black widow alarm/remote starter. http://www.blackwidowsecurity.com/manuals.htm
From your mfrs site -- random PDF manual:
IGNITION LOCK
The ignition locking feature allows the doors
to automatically lock when the ignition key is
turned on, and automatically unlock when
the ignition key is turned off. This feature must
be programmed during installation.
Then another random installation manual PDF, see p16 step 3
http://www.blackwidowsecurity.com/in...ev2%209-04.pdf
oh my god, i must be crazy with this issue, i can't even find any auto repair fix this issue, i'm not a technician, and can't find it out myself
