Sponsored by:
Sponsored by: DashLynx
Cruise Control
Old 08-21-2012
ThatDude's Avatar
ThatDude is an unknown quantity at this point
Cruise Control
This is stupid but i dont have a manual. How do u get the cruise control started in a 01 Civic? I think mine is damaged but I want to make sure im doing it right the Cruise Control light on the button doesnt even come on when i push it
ThatDude is offline
Old 08-21-2012
Prelude Owner
GolNat's Avatar
Re: Cruise Control
First hit this button, the light doesn't have to come on, mine doesn't but cruise still works:
Then hit SET:
GolNat is offline
Old 08-21-2012
palsana's Avatar
palsana is an unknown quantity at this point
Re: Cruise Control
when i hit that cruise button the light doesn't come on nor does the cruise control work when setting for a certain speed?
what gives?
palsana is offline
Old 08-21-2012
rjones7755's Avatar
Re: Cruise Control
You cant use cruise control when your going slow (like less than 25 mph) if thats what you mean by "a certain speed". The reasons why it may not work at all are numerous...do you have led tail lights? have you checked the fuse?
rjones7755 is offline
Old 08-21-2012
palsana's Avatar
Re: Cruise Control
I do not have LED lights and fuse have been removed and checked to see if there was any damage or burnt area and it appears clean
My car barely reaches 70mph I would so much like to set my cruise at 60mi/hr and know its cruising.
palsana is offline
Old 08-21-2012
Prelude Owner
GolNat's Avatar
Re: Cruise Control
Like rjones said there are numerous things that could be wrong with it. Bad main switch, bad set switch,bad brake switch, bad clutch peddle switch, or bad control unit.
GolNat is offline
Old 08-24-2012
ThatDude's Avatar
Re: Cruise Control
My cruise control doesn't work either. is it common to go out after a certain number of miles?
ThatDude is offline
Old 08-24-2012
Prelude Owner
GolNat's Avatar
Re: Cruise Control
I have never owned a car that the cruise stopped working. My first Accord had 290k miles on it and the cruise still worked. Something broke or came loose.
GolNat is offline
Old 08-24-2012
ThatDude's Avatar
Re: Cruise Control
Yeah Ive never heard of CC just stopping. How do I check to see what it is?? I hope its just a simple fuse
ThatDude is offline
robjcivic
03-12-2017 12:10 PM
junkyardguy
09-02-2015 06:07 PM
JetsterDajet
08-16-2015 01:56 PM
2010 Civic
08-10-2015 10:53 AM
Quick Reply: Cruise Control
