02 civic radio question
i got myself a sat radio, now i want to install it both hard wired not using the 12 v socket, what would the easiest way to do this, ideally id like it to be a clean install. also is there a way to wire it to my stock radio, it doesn't have the front AUX port as far as i can see. is there one one the back or can i wire it somehow into the radio.
Thanks
Thanks
Re: 02 civic radio question
There used to be CD changers available that were wired right to the back of the radio in an open connector socket.
I bet you could try to use that for your inputs (may or may not be possible, IDK). You would need some wire diagrams though.
HTH
HTH
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
chgofirefighter
Apr 18, 2015 08:08 PM
