2002 Civic Lx Header??
Old Jan 9, 2012
P228's Avatar
P228 is an unknown quantity at this point
Hi, I saw Magnaflow header with high flow cat built together on http://www.procivic.com/pages-produc...827/index.html and I'm wonder if anyone's had any experience with them. If so, could someone please tell me if they would pass emission tests or if they're street legal?
I'm sure they will probably add little to no power gains but however my exhaust manifold needs to be replaced anyways so I figured I may as well get headers but i dont want to have to use a defouler or anything.
PS: Also tried searching the forum but i couldn't find anything on this specific product.
Any help would be great, thanks!!
Old Jan 9, 2012
lazlong's Avatar
Re: 2002 Civic Lx Header??
Anytime you use a "high-flow" or a cheap aftermarket cat you run the risk of not passing emissions.
Old Jan 9, 2012
lowlife9's Avatar
yeah after market cats are hit or miss so you mite end up using the defouler regardless in order to pass emissions which is very easy since there is no sniffer just obd. if your set indefinitely on a cat then get just a swap on a EX exhaust you can even get a after market EX header and downpipe and use the stock ex cat which is alot cheaper because its not in the manifold also alot easier to replace or repair.
Old Jan 9, 2012
P228's Avatar
Wait.... so does that mean it can actually pass emission? Despite requiring a defouler to fool the car in thinking that it's clean air flowing through?
Old Jan 9, 2012
lowlife9's Avatar
as long as your check engine light is off you should pass emissions where im from they hook up the obd to the computer for 30 seconds and im done no sniffer. i have no cat and i have passed emissions twice already using a defouler or 02 simulator megan brand.
Old Jan 9, 2012
lazlong's Avatar
@ lowife9: Can I assume the O2 sensor wires are extended?
Old Jan 9, 2012
lowlife9's Avatar
no need i have a DX with megan DX header.
Old Jan 9, 2012
lazlong's Avatar
No, I mean going from LX to EX
Old Jan 9, 2012
lowlife9's Avatar
well thats all in the fine print.
Old Jan 9, 2012
P228's Avatar
Uhhhhhhhhhhhhhh........... Has any dx/lx owners tried using these magnaflow headers with high flow cat before?
If so, did anyone cry after getting them?
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
15
Nov 8, 2001 05:06 PM
