bypassing the catalytic converter
Old Nov 26, 2011
cja3455's Avatar
cja3455 is an unknown quantity at this point
is bypassing the cat a good idea ? what's the horesepower gain of doing this ? can one run a valve controlled pipe in parallel to the cat without removing the cat ? so when the valve is open the back pressure is reduced and when the valve is closed everything goes through the cat. Any insights on this subject
Old Nov 26, 2011
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Re: bypassing the catalytic converter
The point of going without a cat is to reduce back pressure. It sounds like a good idea, but the air flow going from the headers to about after the flex pipe is the most important in reducing backpressure. the turns the exhaust has to take to bypass the cat would cause back pressure. the y pipe that you would fit in there would also caust back pressure no matter which path you have open because its not smooth.
Personally, I would weld in an lx downpipe with no cat, and then make the cat on the bypass pipe. a lot of work, but you could have an electronic switch when you get to a certain rpm so you could have good tq at low end and hp at high end. plus youd fool the emissions people XD
Old Nov 26, 2011
complete waste of time, and bad for your health
Old Nov 26, 2011
MindBomber's Avatar
Live for the Twisties
somewhere between 0.1 and 0.2 horse power gain on an otherwise stock engine, with an increase in emissions several fold.
Old Nov 26, 2011
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
agreed. if your that worried about back pressure get some headers and weld in a hi flow magnaflow cat.
Old Nov 27, 2011
lazlong's Avatar
1. Get an actuated valve. They start at about $60 and they look like this:
2. Have the muffler shop weld it in the straight portion of the pipe in front of the cat. Should cost $50-100
3. Wire it to a switch for the emissions test and those pesky officers.
Old Nov 27, 2011
pwnsauce's Avatar
most shops wont weld that in there...becasue "they can be fined" for bypassing it.
however good find. i didnt know such a thing existed, but still theres really no point becasue you wont feel any gain at all and would just be smoggin it up. now with headers and thicker pipes...maybe
Old Nov 27, 2011
RamAirDave's Avatar
RamAirDave is an unknown quantity at this point
hahaha!! WHY???!!!!! lmao!
So it will make 92fwhp?? LOLZ
Old Nov 27, 2011
better bet if youre worried about air flow is a muffler with valve that opens and closes depnding on how much exhaust is being pushed (based on engine rpm) like the rsx type-s jdm exhaust.
Old Nov 29, 2011
Balzdpr's Avatar
A scene before your eyes
Balzdpr is on a distinguished road
or just take the headers clean off and run it like that.
Old Nov 29, 2011
pwnsauce's Avatar
lol do it
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
h4ldol
Apr 24, 2017 08:16 PM
Luluharp
Sep 27, 2015 11:56 AM
pilebuck13
Sep 21, 2015 10:45 PM
