rattling noise diagnostic !!
Old Nov 19, 2011
cja3455's Avatar
cja3455 is an unknown quantity at this point
This noise is driving me crazy and i can't figure out what that is. I only hear it at low rpm and low gears (first and second). So when i put in the first gear and as soon as i remove my foot off the clutch and the car starts moving, i hear this loud rattling noise ( much louder than a bearing rattling, sounds like a tractor or something ), when the rpm goes over 2500 or so the noise kind of disappear. Not sure if this noise completely disappear or the engine noise that is louder at higher rpms is overpowering it. Now, when i shift in to second gear, the same noise popup at low rpm and it kind disappear at high rpms. the noise at second is lower than first though. Third, fourth and fifth gears seem ok, and the car shifts fine at all gears. Anybody experienced a similar noise before ? any ideas what that noise is ?
Old Nov 19, 2011
MindBomber's Avatar
Live for the Twisties
Re: rattling noise diagnostic !!
Is it an EX/Canadian Si?
Old Nov 19, 2011
cja3455's Avatar
it's an 05 EX coupe, not the canadian Si
Old Nov 19, 2011
amamdani15's Avatar
amamdani15 will become famous soon enoughamamdani15 will become famous soon enough
i have the same issue, and i drive a 2004 VP. i just assumed that it had to do with some bearings in the clutch and it would go away when i swap the clutch.
Old Nov 20, 2011
lazlong's Avatar
Check your heat shields. They tend to rust out and rattle real bad. There's one on the exhaust manifold and here's the rest:
Old Nov 20, 2011
i took all mine out. solved tons of rattles and never had any problem. leave the two small ones (7, 8) around the cat because it needs those to work properly. just dont park on tall dry grass because you have a higher risk of the car catching fire without the shields on. our exhausts do not get hot enough to require functional heat shields under normal driving conditions. they are purely a safety measure.
Old Jan 14, 2012
inifiniteblur's Avatar
inifiniteblur is an unknown quantity at this point
are # 26 and 27 hard to get off? that sounds exactly like where mine is rattling.
Old Jan 14, 2012
lazlong's Avatar
You'll have to remove the exhaust to get to it and that's a pain. You'll probably end up having to cut the bolts off. Get up under there before you warm it up and wiggle all the shields to figure out which one(s) it is.
Old Jan 15, 2012
why do you think i'll have to cut bolts?
i bought the car with full aftermarket exhaust and cat. someone else on this site said that those sheilds are probably gone. im not sure if they are or not. i'll give it a look soon...
SimpleUser
Apr 24, 2021 02:54 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
Yazan93
Jul 14, 2015 08:56 PM
fvckbg
Jul 7, 2015 07:08 PM
