Change OEM oil filter every second oil change?
Old Sep 10, 2011
  #31
MindBomber's Avatar
Live for the Twisties
Re: Change OEM oil filter every second oil change?
Originally Posted by Civicnoobie
Oh you check yours when its cold? I thought the oil has to be hot no? Im guessing most people check after they shut it off and wait 5mins?
Checking the oil cold is probably the most accurate way to do so, because you can guarantee that all the oil in engine is in the pan not slowly dripping down. I believe the reason it's not the recommended procedure is that the oil is not at operating temperature and therefore of a lesser volume, despite being an equal mass. If I checked it cold I would just expect the oil to be slightly under the full line to compensate.
Old Nov 24, 2018
  #32
rogerscivic's Avatar
rogerscivic is an unknown quantity at this point
No, seen no oil sludge down in the hole i used just over half a bottle of mmo and drove it around for a awhile stoped by the auto store and bought some castrol synthetic i found at a great price drove it home and just finished with the oil change idles fine oil coloure is back to normal clear again thank-You for all that posted
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
RIPSAW
Nov 6, 2015 04:36 AM
Unleaded
Jun 26, 2007 09:25 PM
Grey
16
Jan 27, 2002 11:34 PM
wawacito
Dec 14, 2001 08:52 PM
