Help Please: Speedometer not working "sometimes"
Old Aug 31, 2011
ctxn1314's Avatar
ctxn1314 is an unknown quantity at this point
2003 Honda Civic LX sedan
Recently my speedometer is not working preperly. The pointer remains ZERO sometimes when I start the car, while everything is running perfetly, engine is running just great. All other pointers in the dash cluster work as normal.
Most starts the speedometer works just fine, occasionally just wouldn't move at all.
Anyone knows what's going on here???Should I worry about anything?
Thanks a lot
Old Aug 31, 2011
lazlong's Avatar
Re: Help Please: Speedometer not working "sometimes"
Do the cluster self-diagnostic in the link and if the speedo doesn't sweep like the others replace the cluster.
http://honda-tech.com/showthread.php?t=2908290
If you need to replace the cluster try:
1. craigslist
2. every craigslist: http://www.allofcraigs.com/
3. eBay
4. http://www.car-part.com/ (pretty much everybody listed is legit)
Old Aug 31, 2011
ctxn1314's Avatar
1. craigslist
3. eBay
Thanks a lot! I did the self-diagnostic, THREE times, everything appears to be in good working condition, all needles swept all the way, all indicators lit up as described!
I guess my cluster doesn't have a big issue. I am wondering could it be some wire or harness has connection issue, and perhaps need a cleaning job. I am no expert in auto maintenance, so please correct if I am wrong.
Thanks for the tips, now I learned something.
Old Aug 31, 2011
lazlong's Avatar
Sounds like a dirty or loose wire/connector, may even be a bad VSS (Vehicle Speed Sensor). Start at the VSS and look for a dirty/loose connection. Clean or repair as necessary. To test further you need a Honda test harness ($$$) and a multi-meter. The only thing you can do on your own without the test harness is to replace the VSS. Go to the link and put in your model. Look under "ATF pipe-speedometer gear" for auto trans and "clutch release" for the manual trans. Either way it's about $70.
http://www.hondapartscheap.com/southbay/jsp/home.jsp
izdman
May 19, 2015 03:43 PM
Chronic_issues
May 8, 2015 05:40 PM
ORskier
May 3, 2015 12:54 PM
dragonsblood
Apr 27, 2015 12:28 PM
smmahan
Apr 15, 2015 08:17 PM
