question about pulling engine?
Old Jul 23, 2011
waddle313's Avatar
waddle313 is an unknown quantity at this point
Ok so i have a 02 ex 5spd civic w/ 130k miles on it. My headgasket has been pushing compression to the cooling system for over a year, and about 20k miles, now. I just fill and bleed the system when every time coolant reservoir fills up, which is every 3 to 6 weeks depending on how much I drive. I'm thinking about finally fixing the car before winter comes but wondering how is everyone on here pulling the engine? From the top or bottom? whole drive train or removing the trans first?
Only reason i'm thinking about pulling the whole engine is because i have also never put a clutch in the car, ive owned the car since it had 11 miles on it. So i figure if i'm going to do the headgasket why not just put a clutch in it also to get it over w/. I hate to put a clutch in it before it goes bad but i also don't want it to go out on me in the winter and the clutch reservoir is at the min line so i assume i'm close to needing a clutch anyway.
One last question.... i'm not a fan of reusing head bolts... they make an ARP head stud kit for this engine i'm sure but do i have to get the older d16 kit? I just never see much that is specifically labled 1.7l
Sorry in advance for my ignorance for this car and parts avalibility. Its just my daily driver and I put all my efforts into a different car i have. I do all the work to the car but only have had to change the timing belt and alternator on the car since ive owned it. its been a great car!
Old Jul 23, 2011
lazlong's Avatar
Re: question about pulling engine?
If you don't have a lift then pull it from the top. You'll have to remove the hood. Just pull the whole engine/tranny assembly. It's fairly simple to pull the tranny by itself but, not the other way around.
The OEM studs are cheap: http://www.hondapartscheap.com/south...t=0&quantity=0
Old Jul 23, 2011
maxtierney's Avatar
EM2ti
I've pulled an engine without a lift or a cherry picker. It's the ghetto way. Loosen all engine mounts, lift up the front of the car with a floor jack, place block of wood under the engine/tranny, pull the mounts, slide the everythng out the front.
ARP Head Studs aren't D17 specific. Use the D16Z.
http://www.dezod.com/pd_arp_head_stud_kithonda.cfm
Good luck.
Old Jul 23, 2011
waddle313's Avatar
I figured pulling it from the top will be the easiest route to go. when you do that are you able to get the engine/trans assy on a good enough angle to pull it out w/ out pulling the subframe?
Old Jul 23, 2011
lazlong's Avatar
The sub-frame (engine cradle) won't come out the top. You have to drop it to remove the engine from the top. With the hood removed the engine will come straight out the top.
Old Jul 24, 2011
waddle313's Avatar
lol.... ^^ i know the subframe has to be removed from the bottom. i'm not that much of a newb
thana
Jun 15, 2020 07:05 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
zack22490
Apr 29, 2015 03:17 PM
cloudguy
Apr 28, 2015 05:02 AM
