Headlight problem
Headlight problem
Hi , I have a big problem with my civic 01 headlight. Yesterday the drl light was on on the dash. In the past, I also had this problem but it solved by itselft. When I roll on hole with my car it light off and on sometime. Now when I start the car I have no drl . I have the driver side high beam on and my halo .. When I turn on the light, the driver side hight beam close and the halo keep light on and the drl light on the dash disapear but the low beam don't work. I also try to re-solder the relay thing , but it did nothing. I know my english is bad . Hope you understand. Please I really need help
Re: Headlight problem
I ran into a simular problum on a 02 civic. Ended up being the connection to the light switch in the steering column. To much resistance and it melted a bit. just had to clean the contacts. But this car had stock headlights I don't know how yours are wired up.
To the OP: He may be on the right track. Definitely sounds like a bad connection somewhere.
stryder12
Jun 30, 2015 08:33 PM
carid
Jun 5, 2015 11:51 PM
intensity
May 12, 2015 10:43 PM
