Crank Pulley: Answers needed!
Old Jan 23, 2011
BobDobolina's Avatar
TRUST me! I'm Idiot Proof!
BobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura about
I will be doing my timing belt/tensioner/seals and a P/S pump rebuild in the comming days, and wondered if anyone has ever had problems removing their crank pulleys...?
Would a pulley removal tool be worth my trouble/money?
How easy was it to remove?
If no pulley removal tool was used, and that SOB was stuck on there, how'd you get it off?
Id like to attack my next project with a full clip, if you know what I mean...
Old Jan 23, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: Crank Pulley: Answers needed!
The crank pulley bolt was a pain in the *** to remove. You can try to get it with an impact gun but unless you have something with MAJOR power it wont even budge it. I HIGHLY recommend buying one of these, it makes life A LOT easier:
http://www.amazon.com/Powerbuilt-648.../dp/B0000TMLWQ
Here is how it is used:
http://www.youtube.com/watch?v=RE-pzP8g_x4
In the video the guy had already cracked the bolt so it seems like it came off real easy. Expect to have much more trouble than he did
You can save yourself a lot of time if you come into it prepared, it's one less thing to trial and error if you know how to do it before you start.
Old Jan 23, 2011
MelJ's Avatar
Trance Addict
+1 to all the above. I didn't do my timing belt job the first time around, but I have heard about the tool sold on Amazon from various Honda sites.
Old Jan 23, 2011
BlueEM2's Avatar
Whachya lookin at?
I pulled my head gasket so in the process changed the timing belt. The way I did it was interesting to say the least but it worked. I had regular ratchet with the crank pulley remover tool on it, and a pipe on the end of it wedged up against the ground. Then I had a 3 foot breaker bar with two 8" extensions being supported with a jackstand (like the video shows). I almost snapped the breaker bar I had so much force going into it, but I got the bolt off in just a couple minutes. Knowing what I was getting into before starting it probably saved me an hour of messing around and a trip to the store to get the tool. Nothing I hate more than having to run out while in the middle of a job!
Old Jan 23, 2011
Thanks for the response, guys. I already got the tool, read it was a total bit#h to it get off without it.
My question is will the crank pulley just fall off when im done? or is it gonna be stuck on there from years of neglect?
I ask because when I went on a hunt for a pulley holder (and never found it, hada order online), all the auto places kept showing me this fancy lookin' claw like tool, told me it was crank pulley removal tool...never saw one used in any DIY for a honda.
Old Jan 23, 2011
BlueEM2's Avatar
Whachya lookin at?
The crank pulley should just pull right off with your hands after you remove the bolt.
Old Jan 23, 2011
Exactly what I was hoping to hear! thanks man!!
Old Sep 21, 2013
saujad's Avatar
saujad is an unknown quantity at this point
We were able to hold our crankshaft by putting a allen head wrench in one of the small holes in our pulley and wedging the other end on the body of the car. Much to our surprise it held and the bolt loosen with our breaker bar.
Did the same in opposite direction to re-tighten the bolt.
Old Sep 29, 2013
civicbyrc's Avatar
civicbyrc is an unknown quantity at this point
after you wiggle the pully off make sure you watch for the key. its a small rectangle piece of metal that aligns the crank pulley to the crankshaft. very important.
Old Oct 16, 2013
avenger's Avatar
avenger is an unknown quantity at this point
this
Old Oct 16, 2013
BlueEM2's Avatar
Whachya lookin at?
This two year old thread keeps getting revived ...
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Trav_02civic
Apr 23, 2015 08:57 AM
Myredjonda
Apr 14, 2015 07:00 PM
3rdcivic
Oct 21, 2001 01:26 PM
