What is this screw for???
Old Dec 31, 2010
2002ExCivic's Avatar
2002ExCivic has a spectacular aura about2002ExCivic has a spectacular aura about
I have a 2002 ex civic.
everything is stock completely haha
I dont even know if this is from my car, but I am 90% certain it is.
This is the screw (first picture) and I think it goes here(second picture).
but i dont know for sure... what is that second picture anyways?
ID:	79899   Click image for larger version
Old Dec 31, 2010
Re: What is this screw for???
that looks like the wingnut for the alternator! doesnt belong anywhere in the second pic area. it looks like you are missing an air intake bolt tho. lemme try and snap a pic, i remember seeing that bolt a few days ago. its not the one at the top of the bay where the power steering is, its down below in the front where alt is. i had mine almost fall off once too and the belt started squealing. i prolly have a spare bolt for the air intake if you want. just pay shipping and packaging $2.
Old Dec 31, 2010
lazlong's Avatar
Sits on the PS pump like this:
Old Dec 31, 2010
top one on the PS pump should be easy to see if there is a hole in that spot. otherwise its the bottom one. here you can see it peeking out under the alt. i really have no idea how you are able to drive with that missing.
Old Jan 1, 2011
BlueEM2's Avatar
Whachya lookin at?
Once the wingnut is adjusted and the other bolts are holding the alternator in place that wingnut can fall out with the alternator not moving. Not really a good thing by any means though. Get that back in A.S.A.P.
Old Jan 1, 2011
DarkSouljur's Avatar
DarkSouljur has a spectacular aura aboutDarkSouljur has a spectacular aura about
Question: What is so important about it, like what does it do?
Old Jan 1, 2011
keeps the alternator belt at the proper tightness. if it falls out, you wont have a charging system and the alternator may get damaged. the shop said my belt was so loose, it was visibly wobbling and they were shocked the charge system light didnt come on. it was also squealing like crazy all the time. they tightened it back up and all the problem went away. i just never noticed it cause i usually only have the hood open with the car off.
Old Jan 2, 2011
thank you guys so much, i'll look into it tmrw since I don't work haha.
and its raining hard right now.
I am guessing it is not the alternator one, its been out for months. lol damn.
my brother was kind of just flooring it and he clutched really hard. i heard it drop and went back to pick it up, off the street.
Anyways I do have a screech in a belt. I posted before on these forums for help; i doubt the noise has to do with the valve clearance, so i just ignored it.
thanks though. I'll post up tmrw as soon as I check it out.
Old Jan 2, 2011
Its not from the PS! Wow I can't even put it in the alternator. My hand doesn't fit. And how will I know when its tightened enough? How much would I get charged by a mechanic? Help
Old Jan 2, 2011
MelJ's Avatar
Trance Addict
Is the alternator belt tension adjustment different for the 7th gens? I don't think my 6th gen has a wing nut. When I had to adjust the tension for my alternator belt, I had to use a crowbar to move the alt up and down. I mean, this was 2 years ago, so I could be completely off . I went underneath for better access. I have big hands and I ran into the same damn problem on my other car.
Old Jan 2, 2011
shop only charged like $10 to put it back in. easy with the car raised up i guess.
Old Jan 2, 2011
BlueEM2's Avatar
Whachya lookin at?
If I remember correctly this wingnut is only for setting the tension, after the other bolts are installed they hold the alternator in place To prevent the crowbar method
Old Jan 2, 2011
So it should be easy to just tighten it up by hand right
Old Jan 4, 2011
well i had to go under and remove a black cover, but i got it in. there was also something else loose so i tightened both up and now there is no noise yess..
ricer_em2
May 11, 2016 08:09 PM
redcloud
Sep 7, 2015 01:45 PM
Klame9420
Aug 13, 2015 06:00 PM
ballmich
Jul 9, 2015 11:59 AM
