True 7th gen potential
Old Dec 29, 2010
  #31
DarkSouljur's Avatar
DarkSouljur has a spectacular aura aboutDarkSouljur has a spectacular aura about
Re: True 7th gen potential
Originally Posted by sdaidoji
and the damned anzo's in front with the block heater plug hanging in front
Are u saying Anzo's are good or bad? I was thinking of getting a pair when i got my civic lol
Originally Posted by MelJ
BAHAHAHA!!
Old Dec 29, 2010
  #32
MindBomber's Avatar
Live for the Twisties
It's possible to make 400hp+ easily on a K, its a completely different motor.
The stock block record for a d17a2 is under 300hp, running close to 30lbs of boost. Did you mean without or with cams, because realistically you won't break 225hp without building the head. The size of turbo helps, but its only one small factor in the equation, swapping in the biggest turbo out there won't help you. Not trying to be a dick, it just sounds like you need to do a hell of a lot more research before you go any further. For example, running 93 octane without having an EMS installed is completely useless..
Originally Posted by pb_boosted_es2
Not looking to set records and yea, saw his 490 hp build, idr if that was whp or to the crank.. But i'm hoping to do so on 15-20lbs of boost. My aim's are to reach my goals on 15lbs without cams and all that. Do intend to build the head to be able to with stand 11,000rpm & have the cranck balanced to about 13,000 for safety.
If i gotta go over 15lbs i will have to swap my intake mani. Which i plan to do sooner or later.
& i do know it's easier to make 450-500whp with the k.
My boy has a 06 si on 12lbs making 440whp. Stock motor. Idr what size turbo. As i said b4. The size makes a difference.
But if u don't plan on doing over 500. I personally don't see the point
Old Dec 30, 2010
  #33
mac25's Avatar
Dr Krieger of Modification
true that. i used to use 93... before i found out it does nothing in a low compression engine. when i switched to basic, it was noticably slower feeling till i reset the ecu, after that it felt the same.
Old Dec 30, 2010
  #34
low light output, but still better than my beat-up stock one that i took out.
Old Dec 30, 2010
  #35
niiice old subies! like these more than the bug eye type! the evo's did copy part of the headlight design?!?
Old Dec 30, 2010
  #36
pb_boosted_es2's Avatar
pb_boosted_es2 is an unknown quantity at this point
Sweet, I'll look into getting one, if possible, can you do a rev video?
Sorry about the late reply on ur post, i mostly skim being at work and at my girls house. But i can try and get u a vid asap. A rev up. Take off (don't like doing those) & a drive by so u can get a good idea of how it sounds. I'll try working on it tonight being the local meet tonight & piece them together
I'd really like to hear it.
Old Dec 30, 2010
  #37
Kennykid2002's Avatar
Kenny the Ricer
Nice, i'm looking forward to see it
Old Dec 30, 2010
  #38
Before i build i was actually aiming to make 300whp with a t3/t4 turbo. Intake mani swap. A little more boost & fuel & sure with a standalone. If i would to make atleast 260whp, i wouldn't have a problem with that. But i believe some way some how it can be done.
& someone threw 30lbs on it?
Do u know how much the stock block can handle safely? I spiked 12lbs once halfway openning my throttle and backed off. New wastegate diff settings caused my spike
Old Dec 30, 2010
  #39
MindBomber's Avatar
I would be nervous and have a spare engine ready, if I ever pushed my block passed 15lbs, but a few people have pushed as high as 20lbs of boost on a stock block I believe. The block is so weak on Honda engines, it actually bends and flexes a bit around the crank shaft, which is one of the reasons Honda builds such perfect cranks.
I think you would could make 260whp if you had a built head, a good cam would make a huge difference on a turbo'd engine.
Old Dec 30, 2010
  #40
That or u jus got used to the feeling of running on less than 93oct by that time.
Old Dec 30, 2010
  #41
Lol... I'm scared to pass 9.5/10lbs daily.
That's why i stay at 7.5lbs making 206whp 180+tq on a piggy back, aem fi/c & a bby snail
& yea i was talking without cams.
Old Dec 30, 2010
  #42
Would HIDs make a difference?
Old Dec 31, 2010
  #43
read the TYC retrofit thread
Old Jan 2, 2011
  #44
video coming soon. been recorded. needs to be edited
Old Jan 2, 2011
  #45
I actually just found a video of a call out of a call out by a new gen sentra se-r. you can barely hear my exhuast at full throttle. so quiet it's muffled by the se-r.
Funny thing is i got called out by two se-r's. a new gen and the gen before. new gen was the only one that showed while the other backed out. and the video car was a Altima SE-R. he got ate after I ran the se-r. but they fail to let me have the video.
Old Jan 6, 2011
  #46
The video has been uploaded to youtube under "miss berry" but there's an audio problem. But it plays on my phone. I'll look more into it later
JetsterDajet
52
May 8, 2016 12:11 AM
sesi
Oct 1, 2015 02:03 PM
Nalmonte
Sep 28, 2015 01:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Donahue
Sep 8, 2015 10:43 AM
