About my 04 civic brake lights is out
Hi guys, recently one of my driver side brake light is out, a week later passenger side brake light is out too , plus crusie control is not working after both of the lights is out. crusie control button has green light but not on the dash board.
Would that be bad brake light switch? Fuse?
Re: About my 04 civic brake lights is out
Just a quick dummy check, you did check the bulbs if they were burned out, yes?
And if you have no brake lights, your cruise won't work. It's a safety interlock or something. But, that would also mean your third brake light was out, too.
Test to see if your getting power to the sockets. If your getting power to the sockets it's bad sockets. Sometimes they actually go out near the same time.
edit: CC won't work if the third brakelight is an LED. Looking at the diagram the only things to test in the circuit are the relay and brake pedal position switch. Neither of which I think is the problem as the third brakelight wouldn't work if either was bad. This points even more to bad sockets.
Xuhme
21
Aug 7, 2023 03:40 PM
civic_gt
Apr 19, 2015 08:15 AM
